Old 07-30-2004, 01:10 PM
FLUTE HEAD's Avatar
Gold Member
FLUTE HEAD is on a distinguished road
current per phase for power supply?
driver When designing a power supply, is one to look at phase current or rated current of stepper motor? ex. 2 phase motor rated at 5v 3amps. Lets say a three axis machine. Would I design my power supply for 3amps x 3=9amps or would it be 3amps x 2phase=6amps x 3 motors= 18 amps.I understand that depending on the driver I use will make a difference on the percentage of amps to use in the calc., something like 67% of total amps(ex. a chopper drive). What about without a chopper drive, should I go with the total amps + 20% to cover all bases? I seem to be using a basic bipolar drive. The one on electrokits.com
Old 07-30-2004, 02:36 PM
ger21's Avatar
With that drive, yes, add up all the amps for each phase. 3a/phase times 2 phases/motor = 6 amps times 3 motors = 18 amps. I'd maket it at least 20.
If you used Gecko's, on the other hand, you'd only need about 6 amps. You'll be wasting a LOT of power through your resistors.
Old 07-31-2004, 08:40 AM
FLUTE HEAD's Avatar
Gold Member
ALSO, What is the amp rating refering to on most stepper motors(per phase amps or total amps)?
Old 07-31-2004, 12:41 PM
ger21's Avatar
per phase
How does a power supply work. ynneb DIY-CNC Router Table Machines 1 07-27-2011 09:40 AM
Staggering motors viktorcnc Stepper Motors and Drives 12 10-12-2005 04:56 AM
Need more power mvaughn General Electronics Discussion 49 06-15-2005 06:11 AM
Series Bipolar and parrallel bipolar? CNCadmin FAQ of CNC Machine building 0 09-08-2004 07:17 AM
Egads! 3 Phase power supply? samualt General Electronics Discussion 5 10-02-2003 08:37 PM
