Old 07-29-2004, 04:00 PM
FLUTE HEAD's Avatar
Gold Member
FLUTE HEAD is on a distinguished road
Transformer Vct?
Can Someone Explaine What Vct Means In The Description Of Most Power Transformers? I Would Like To Find One Close To 20vac Secondary And 80.4 Va. I Was Trying To Find These Figures.
Old 07-29-2004, 04:11 PM
Al_The_Man's Avatar
Vct usually means the secondary has a centre tap, so 40vct would mean that it has a 20v-0-20v winding which means you can use it two ways, with two rectifiers one on each of the 20v connections will give you a full wave rectified DC with respect to the 0 tap. which will be 20vac rectified or you can ignore the tap and wire a rect. bridge across the two 20v ends and get a 40vac .
Al
Old 08-17-2009, 02:31 PM
andria85 is on a distinguished road
Center tapped transformer
How to select the filter capacitors before and after the regulator? is here any formula??
How to wire a toroidal transformer..need advice bgolash General Electronics Discussion 15 11-12-2007 08:22 PM
Microwave transformer built power supply TinkerDJ General Electronics Discussion 64 08-13-2005 06:19 AM
3 phase transformer on single phase? jevs General Electronics Discussion 4 03-19-2005 11:25 AM
Connecting power transformer to 3 phase keithorr General Electronics Discussion 3 12-17-2004 01:52 AM
vct and vac senor J. General Electronics Discussion 2 10-28-2004 06:39 AM
