Old 03-09-2008, 12:27 AM
Monte is on a distinguished road
Sizing a power supply smoothing capacitor
My numbers for a 41 vdc power supply
3 axis @ 4.2 amps/ motor = 12.6 total possible motor amps
12.6 * 0.667 = 8.4 amps for 2/3's minimum power supply rating
14*2*1.414 = 39.6 I have (2) 14v transformsers that I'll series together, 39.5 is close enough
80,000*8.4/39.5 = 17013uF
I have a 20,000uF 50vdc cap, is that close enough? How close up or down do the capacitors need to be to the calculated value?
Thanks,
Monte
Old 03-09-2008, 12:56 AM
smarbaga is on a distinguished road
hello
your calcs. looks good.
a rule of thumb :
2000 uf per amp.
Old 03-09-2008, 10:12 AM
vger's Avatar
vger is on a distinguished road
Only problem I see is with the voltage rating. With 40 volts RMS you get about 56 volts peak, enough to damage a 50 volt cap. Many electronics manufacturers will approximately double rate the voltage of capacitors. If the voltage in the system is 56 volts they would use a 100 volt cap.
Steve
power supply sizing vs. servo rating Erick Davidson General Electronics Discussion 1 06-06-2006 03:08 PM
Capacitor for Unrelated Power Supply chad_s General Electronics Discussion 9 12-05-2005 05:21 AM
Power supply capacitor itsme General Electronics Discussion 7 06-29-2005 07:38 AM
Hazard due to power supply capacitor owhite General Electronics Discussion 2 07-12-2004 11:44 PM
Sizing servo power supply? bsc52001 DIY-CNC Router Table Machines 2 01-30-2004 11:20 PM
