I have 4 servo motors which are simular, there all dc motors which i think are good canadates for adding encoders, the motors frames are 84.5 mm sq..face which i think are nema 34 compatable which motor has the better spec and why? spec are as follows motor1 skewed rotor design yes maximum operating speed: 4200 rpm continuous torque: 1.2N.m whats this in oz/in ? torque constant (KT): .1757 N. m/am peak torque: 6 N.m whats this in oz/in ? voltage constant (KE): 18.4 volts/100rpm terminal voltage: 72 VDC - resistance: .68 ohm continuous current: 7.6A - inductance: 2.35 mH peak current: 38A - weight: 8.8 lbs inertia: 3.39 kg.cm^ - 7 inches motor 2 skewed rotor design yes maximum operating speed: 4200 rpm continuous torque: 1.2N.m whats this in oz/in ? torque constant (KT): ? N. m/am peak torque: >12 N.m whats this in oz/in ? voltage constant (KE): ? volts/100rpm terminal voltage: 80 VDC - resistance: ?ohm continuous current: 9A - inductance: ?mH peak current: 80A - weight: 8.8 lbs inertia: 3.39 kg.cm^ - 7 inches motor3 skewed rotor design yes maximum operating speed: 4200 rpm continuous torque: 1.2N.m whats this in oz/in ? torque constant (KT): .1443 N. m/am peak torque: >12 N.m whats this in oz/in ? voltage constant (KE): 15.12 volts/100rpm terminal voltage: 72 VDC - resistance: .52 ohm continuous current: 8.8A - inductance: 1.83mH peak current: 80A - weight: 8.8 lbs inertia: 3.39 kg.cm^ - 7 inches motor4 skewed rotor design yes maximum operating speed: 4200 rpm continuous torque: 1.2N.m whats this in oz/in ? torque constant (KT): .1757 N. m/am peak torque: >12 N.m whats this in oz/in ? voltage constant (KE): 18.4volts/100rpm terminal voltage: 90 VDC - resistance: .52 ohm continuous current: 7.6A - inductance: 2.35mH peak current: 80A - weight: 8.8 lbs inertia: 3.39 kg.cm^ - 7 inches A quick question, Is the inductance directly related to how strong pm feild is? |
| They all appear to be suitable candidates, I assume you mean DC Brushed? If you google for a converter, you will see dozens e.g. http://www.cleavebooks.co.uk/scol/cctorq.htm The inductance probably originates from the amount of magnetizable material within the coil at/under the comm position. Al.
| Stepper motor spec? | benergy | Stepper Motors and Drives | 3 | 01-28-2008 04:26 PM |
| NEMA motor frame spec | damae | Mechanical Calculations/Engineering Design | 7 | 01-19-2006 01:27 AM |
| Hooray got motor spec sheet | eat | Servo Motors and Drives | 0 | 10-03-2005 04:49 PM |
| Allen Bradley Servo spec help | CAM_MAN | Servo Motors and Drives | 1 | 02-23-2005 11:00 PM |
| Stepper motor spec' source & question | Damachine | DIY-CNC Router Table Machines | 4 | 04-06-2004 01:01 PM |
