im planning on using servo motors with my cnc router 5x9 table with g32o driver (2 motor on y axis slave also), I like to use mach 3 with a laptop. But it has no parallel port what are my options, grex or a cheaper solution, i still like to use the laptop if possible? do i still need a break out board if i use grex? |
| The SmoothStepper should be released in the next few weeks, and is cheaper than the G100. www.warp9td.com
what are the features of this unit, im guessing no break out broad required?, is it optical protected etc? how does interface with geckos? does it have spindle on off controll? anyone use them or have feed back? |
| They are in beta testing right now. It's a USB connection pulse generator, with a 4Mhz step rate. It basically creates two parallel ports and connects to the PC with a usb cable. You would still use one or two breakout boards and plug them into the SmoothStepper parallel port connectors.
| Need Help!- Anyone know anything about this setup? | adbradley | DIY-CNC Router Table Machines | 4 | 01-24-2008 04:18 PM |
| DeskCNC 2nd. gen controller AND HobbyCNC Pro Controller | maycom | DeskCNC Controller Board | 1 | 06-02-2007 01:33 PM |
| DNC Setup | phoodieman | General CNC (Mill and Lathe) Control Software (NC) | 6 | 12-18-2006 05:55 PM |
| What is your setup? | dolanosa | CNC Wire Foam Cutter Machines | 5 | 10-09-2005 02:00 AM |
| Parts list for a typical controller setup | bgolash | Gecko Drives | 1 | 09-20-2004 08:20 AM |
