Old 07-27-2004, 02:59 PM
FLUTE HEAD's Avatar
Gold Member
FLUTE HEAD is on a distinguished road
Components For Parallel Port Distribution
I Have 3 Bipolar Stepper Drivers For A Three Axis Machine. In Order To Connect This To My The Parallel Port On A Pc, Im Assuming I Need To Solder A 25 Pin Male Connector To A Blank Pcb And Tie In All Drivers To This One Board. Are There Any Other Components Besides Male Port Connectors, Wire, Circuit Board? Im Trying To Gain The Basic Idea Here. Any Help? Ive Only Got Basic Electrical Understandings. Any Other, Easier Ideas?
Old 07-27-2004, 03:37 PM
pminmo's Avatar
pminmo is on a distinguished road
Break out boards are sold a number of places. DB25 connector on one end, terminal or solder connections on the other. In some instances logic for kill and home switch's, sometimes opto isolation.
Phil
Old 07-27-2004, 03:51 PM
Dan Mauch is on a distinguished road
Breakout boards
I sell a low cost simple db25 breaout board kit that has a db25 connector on one side and screw terminals on the other side using a pcb to make the connections. See my product section at www.seanet.com/~dmauch
Dan
Dan Mauch
Camtronics Inc
dmauch@seanet.com
Old 07-27-2004, 04:24 PM
FLUTE HEAD's Avatar
Gold Member
Thank You All
Old 07-27-2004, 09:27 PM
GaryM is on a distinguished road
Could use a little help locating components. I have found the 78HC14N at mouser.com but components like the 4030N and the 4013N I can't seem to find. Is there a way to cross reference these number's? Where would be the best place to get these components?
Thanks!
Gary
Old 07-27-2004, 09:30 PM
pminmo's Avatar
www.digikey.com or www.futurlec.com. Futurelec is usually cheaper, but the parts are shipped from Singapore usually takes at least 2 weeks.
Old 07-28-2004, 09:00 AM
FLUTE HEAD's Avatar
Gold Member
HEY GARY, IF THESE ARE IC CHIPS YOU CAN GO TO FINDCHIPS.COM, TYPE IN THE NUMBER, AND A LIST OF MANUFAC. AND SUPPLIERS SHOULD COME UP. I think they should even have spec sheets. matt
Old 07-28-2004, 09:07 AM
Hey, thanks alot guys. Sorry, but I am really dumb about electronics. Plan on learning though!
Gary
Old 11-03-2004, 11:01 AM
c_nut is on a distinguished road
Gary
Try adding a CD in front of the number as these are CD4000 series parts.
Also the CD4030 can be replaced with the CD4070 without changing anything including pin numbers.
c_nut
Parallel port circuit Kerri Ann General Electronics Discussion 12 03-19-2005 12:23 AM
Need suggestions on components 5 axis control system? pab Mach Software (ArtSoft software) 0 01-19-2005 04:34 PM
Parallel Port Options JasonCroyle General Electronics Discussion 4 01-12-2005 07:23 AM
Serial or Parallel port drive Max General Electronics Discussion 8 11-02-2004 12:20 AM
Using A Laptop Without Serial Port mtech Computers and Networking 6 08-17-2003 08:58 AM
