Old 03-07-2008, 11:25 AM
krymis is on a distinguished road
optical limit for x2
How does Industrial hobbies use one optical limit for Home and bot limits? Where would I found a switch like that? I know the digikey switch was talked about but that is only one sensor. It would be nice to have an IH similar setup.
http://www.industrialhobbies.com/how...optical_limits
http://www.industrialhobbies.com/how...structions.htm
http://www.cnczone.com/forums/showth...optical+limits
Old 03-07-2008, 03:13 PM
acondit's Avatar
acondit is on a distinguished road
The switch has a trigger bar that can activate from either side. So for example on your X axis you would mount the switch itself on the XY saddle and two stops one towards each end of the table (such that they activate the switch at the appropriate point).
Then EMC2 allows you to specify that the limit switch(s) and home switch are shared.
Alan
http://www.alansmachineworks.com
Old 03-07-2008, 10:38 PM
thanks
Old 03-07-2008, 10:39 PM
Al,
Could you please delete as the info has been gone over many times before.
Old 03-08-2008, 12:18 PM
tpworks's Avatar
tpworks is on a distinguished road
There are two switches side by side, here is a close-up of the ones that I am making. Using digikey part
http://search.digikey.com/scripts/Dk...name=H22LOB-ND
http://www.tpworks.net/P1010013.JPG
...He who makes no mistakes makes nothing! ...
Tom
Old 04-17-2008, 10:44 AM
BeerFizz is on a distinguished road
Hi tpworks,
could you please post the circuit you are using.
Phil
My New Optical Toy Micro Rotors Benchtop Machines 58 03-01-2008 09:45 AM
optical limit switches woffler Benchtop Machines 7 12-17-2007 05:01 PM
Optical Limits JOE65 Industrial Hobbies (Support forum) 1 03-21-2006 10:06 PM
optical limit switches phantomcow2 DIY-CNC Router Table Machines 4 03-05-2006 06:48 AM
Optical Limit/Home/Reference Switches redbaron DIY-CNC Router Table Machines 5 02-06-2004 07:47 PM
