On my homebrew CNC woodrouter I'd like to control the motor via a solid state relay via a spare port off controller board. I see a bunch of these relays on eBay but many list the specs which say they can't be used for inductive loads, although they will handle the current and AC voltage. I thought about just using a JFET switch off the port to turn on/off a heavy duty mechanical relay which will then control the motor - this would get me around any problems with inductive loads, but this is sorta a "messy" solution. Anyone have any advice with the SS Relays? |
| I bought a solid state relay to run my spindle motor. I didn't realize that there is more to it that just that. It was cheap though. ![]() I might eventually build a circuit that can use it. There were a couple of old threads here somewhere that explained and had a diagram about how to use SSR with cnc stuff. I just did a search and came up with those threads then. I decided to get the relay card from CNC4PC. They have several different types and one should suit your needs. Reasonable on cost as well. I still haven't had time to install these yet, but I will get there one day.
__________________ Lee |
| The majority of AC loads are inductive and SSR's are used all the time for this, as long as the rating is OK and most are Zero switching, these switch the inductive load as the voltage wave form passes through zero. If relatively high loads like large contactors or solenoids etc, a snubber across the coil is recommended, if the current is slightly out of phase a snubber will help. Al.
| Router 0/1 with solid state relay | bigz1 | General Electronics Discussion | 6 | 04-24-2008 08:37 PM |
| Solid state welder schematics? | DennisCNC | General Electronics Discussion | 0 | 07-09-2007 04:55 PM |
| Solid state relay | N4NV | General Electronics Discussion | 13 | 05-07-2006 12:19 AM |
| Solid State Relays | vertcnc | General Electronics Discussion | 11 | 11-30-2004 06:45 PM |
| Solid state limit switches | Swede | General Electronics Discussion | 0 | 01-03-2004 06:22 PM |
