Old 07-26-2004, 07:42 PM
owhite is on a distinguished road
Circuit debugging question. Re an 8-bit comparator
I am trying to make a circuit similar to the one I described here:
http://cnczone.com/forums/showthread.php?t=5366
except this binary counter will have 8-bit resolution. I have some circuit simulation software and when I hook my 74LS682 in the following way I cant seem to get it to register that word it is comparing has changed, that is, it goes from 00000000 to 00000001 when I depress the button.
Any suggestions?
Owen
Old 07-26-2004, 07:55 PM
pminmo's Avatar
pminmo is on a distinguished road
As depicted, when you press the button, they will be equal. There are unequal in the undepressed state. As show pin 19 will be false (hi), when you push the button and make equal it will go true (low).
Phil
Old 07-26-2004, 08:34 PM
I guess i could put the question this way: why does my simulator give the same voltages for these two different circuits?
o
Old 07-26-2004, 09:16 PM
Al_The_Man's Avatar
Owen, Is it because it is a 3state device? I do not have a spec sheet for this, do you have a link for it? I saw one application where p0 was designated AEN (address enable). I found the app sheet, what happens in the simulator if you place a pull-up resistor on the metered pin?
Al
Old 07-26-2004, 09:40 PM
Spec sheet.
http://www.nilno.com/laser_dir/pdf/74ls684.pdf
Old 07-26-2004, 10:18 PM
pminmo's Avatar
I don't think it should. No it's not a tristateable.
Phil
Old 07-26-2004, 11:08 PM
grumble.
owen
Old 07-27-2004, 04:20 PM
DR-Motion's Avatar
DR-Motion is on a distinguished road
Owen,
Just an observation... but I don't see a Vcc and GND connection for the 'LS682...just for the logic inputs.
Gary
edit... or maybe your simulator does it for you?
embrace enthusiasm to accomplish the task
Gary Davies... www.durhamrobotics.com
Old 07-28-2004, 12:35 AM
yeah the simulator assumes those get hooked up and doesnt display 'em.
o.
Old 07-28-2004, 04:13 AM
tachus42 is on a distinguished road
Works for me using B2 Spice must be something not quite right with your simulation setup or part model.
ID:	2943   Click image for larger version
  #11   Ban this user!
Old 07-28-2004, 08:07 AM
tachus,
what was designation of chip did you use? 74LS5684 or something else?
and thanks much for taking the time to try it out.
owen
  #12   Ban this user!
Old 07-28-2004, 09:05 AM
It was the ls682.
Question on Bit Sizes???? diogee02 DIY-CNC Router Table Machines 3 06-02-2005 07:22 PM
Router bit feed rates. ynneb DIY-CNC Router Table Machines 3 05-28-2004 11:54 AM
Help w/ e-stop circuit design owhite General Electronics Discussion 4 03-07-2004 08:16 AM
