Old 07-25-2004, 09:40 AM
Wanna be
Hack is on a distinguished road
Question Quick servo vs stepper questions
When building a 3 axis router is there any thing other than the electronics and how to mount either type of motor that needs to be taken into account. I have been doing some drawings for a machine and haven't decided what type I want to use and don't want to get to far into the project if there is something else to consider.
Check out what I am working on at www.routerbitz.com!
Old 07-25-2004, 11:13 AM
Patrick2by4's Avatar
Gold Member
Patrick2by4 is on a distinguished road
that's a big question. First ask yourself what are your needs, wood only? foam? aluminum? printed circuit boards?
what size work envelope do I want?
How much money am I willing to spend?
You also need to read about the different projects people built, what is your skill level, what do you think you can reasonably build?
-Patrick
_____________________________________________
measure twice, cut once - a good rule for everything
Old 08-04-2004, 03:03 AM
RotarySMP's Avatar
RotarySMP is on a distinguished road
Marriss, the designer of Geckos suggests the following rule of thumb. Below 60W per axis drive power, choose steppers, above 100W use servos, between these values depends on the application.
Regards,
Mark
www.wrathall.com
Old 08-04-2004, 05:18 PM
snaggletto is on a distinguished road
No, it really doesn't matter. Just make sure you leave the motor mount areas big enough to accomodate smaller or bigger motors. Many servos and steppers have similar mounts. For example the NEMA23, and NEMA34 standards apply to both steppers and servos.
Steppers need to be oversized for the application, so that they have more than enough torque for almost any situation on the machine and thus will never/rarely loose steps. Steppers can be nice as they act like a brake when not in motion. This can come in handy with a heavy Z (vertical) axis.
Servos are definitely superior in terms of smoothness, speed, and a wide spread of torque.
Old 08-04-2004, 09:17 PM
ger21's Avatar
I thought I read steppers below 100W, Servos above 200W, either in between? And I also read this from Mariss. Maybe the 200 was 150, but I'm pretty sure 100W was the low cutoff.
Old 08-05-2004, 01:48 AM
RotarySMP's Avatar
Opps, Thanks for correcting that.
As Hack is looking at a three axis router, I would guess you will be in Stepper country.
Regards,
Mark
www.wrathall.com
stepper, half step, servo?? which to get? blazer928 General Electronics Discussion 4 04-13-2005 12:28 PM
Mixing servo and stepper ty1295 Servo Motors and Drives 0 01-19-2005 09:26 AM
Another which should I get Servo or Stepper Question. mysterious General Electronics Discussion 31 04-05-2004 12:02 PM
Motor selection advise needed? Servo or Stepper Beezer DIY-CNC Router Table Machines 1 03-21-2004 12:24 PM
Stepper or servo moters (Lots of ?'s) Toolmaker DIY-CNC Router Table Machines 29 02-22-2004 09:49 PM
