Hi, Stupid question but.. I need some new cables for the welder so I got some 35mm2 welding cable. The local electric shop sold me some cable lugs to fix the cable to a 8mm post. The lugs I have are marked 35-8 This means they take a 35mm2 cable and have a 8mm hole in the lug part. Now, I have one of those (cheep far-east) hydraulic 16ton crimpers, I put in the pair of dies marked 35mm and crimped up the lug but its not qiute as tight on the cable as I would like. Am I doing something wrong? Should the die marked '35mm' be the right one for 35mm2 cable and 35mm lugs? The next size die down is 25mm and deforms the lugs too much. Should I just tin the ends of the cable to make it slightly larger before crimping it? Many thanks! |
| At one time we used to pot lugs like that with using solder stick and no crimp, but evidentally it is frowned on now. You could either solder pot them afterwards. Or can you shim the dies slightly? Al.
| hydraulic help | byoung0454 | Mechanical Calculations/Engineering Design | 4 | 01-08-2008 10:29 PM |
| Hydraulic Problem | bherr | Bridgeport and Hardinge Mills | 0 | 06-28-2007 04:07 PM |
| Hydraulic spindle? | Nivea | DIY-CNC Router Table Machines | 4 | 06-18-2007 12:47 PM |
| Which Hydraulic Oil do I use????? | bherr | Bridgeport and Hardinge Mills | 2 | 06-12-2007 08:01 PM |
| hydraulic chuck | Runner4404spd | Mini Lathe | 9 | 02-11-2007 04:46 PM |
