02-26-2008, 10:17 AM
 | Community Moderator | | Join Date: Mar 2003 Location: Shelby Twp, MI....USA
Originally Posted by SPEEDRE When I get to wiring my limit switches is it ok to use a connector, as in, having them plug in on a faceplate? I plan on using a new electronics enclosure of my own design and I want everything to plug in at the faceplate. |
Yes, you can do that.
Originally Posted by SPEEDRE Also, I have a bi-directional bobb from cnc4pc and mini power supply for it. It has a place to put an enable/disable switch. Can this be utilized as an E-Stop, as it will stop the flow of information to and from the computer, as I understand it? |
Yes, but your control software will keep running, unless you tie the estop input into the switch as well.
__________________ Gerry
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
