Old 02-21-2008, 12:10 PM
SPEEDRE is on a distinguished road
Schematic for Limits switches
I have Radio Shack SPDT Submini roller lever switches I'd like to use as limit switches. First can I ?, and how to wire them. See pdf attached for dwg's. I am electron challenged. Help
Old 02-21-2008, 01:11 PM
Bubba's Avatar
Bubba is on a distinguished road
The way I would do it (assuming direct connection to a bob or the parallel port is to connect C (common) to ground and pin 2 (NC) to the port with a pullup resistor connected to 5V (probably about a 470 Ω resistor. This will give roughly 10 ma current through the switch.
Then set your controller to active high. This way, the controller will see 0V under normal conditions and will see 5V when the switch is tripped (OR if some of the wiring were to somehow fail.
Art
Old 02-21-2008, 02:55 PM
pminmo's Avatar
pminmo is on a distinguished road
Maybe this will help some: http://pminmo.com/PMinMOwiki/index.p...limit_switches
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 02-21-2008, 08:01 PM
More Questions on Limits
Thanks the link is helpfull. But what is a bob? Is it breakout board? And how does using a breakout board effect the schematics
Old 02-21-2008, 09:16 PM
pminmo's Avatar
BOB = break out board. It's a method to wire to the parallel port connector easily when you don't want to solder or crimp pins. Usually a BOB has screw terminals that are numbered/connected to the associated pin on the parallel port db25 connector.
How to set up limits w/out home switches bullseye Mach Mill 5 10-26-2007 05:44 PM
Home / Limits switches borrisl Shopmaster/Shoptask 12 03-30-2006 09:25 PM
The relationship of limit switches to home switches. MikeAber General Electronics Discussion 4 11-04-2004 01:28 PM
Home switches and limit switches. ynneb General Electronics Discussion 5 04-08-2004 05:32 PM
Limits, homing, and relay switches Bloy2004 General Electronics Discussion 3 11-24-2003 05:17 PM
