Old 02-19-2008, 12:22 PM
GMill7 is on a distinguished road
Lathe VFD conversion
Hello,
I want to convert a Prazi SD400 (8x14) lathe to variable speed, without a loss of torque at slower speeds. The current motor is 1/2 hp. What would be the best VFD/ 3ph motor combination to accomplish this task. Thank you for your replies.
Greg M.
Old 02-21-2008, 06:32 AM
vger's Avatar
vger is on a distinguished road
Did you change the motor already? The stock SD400 has a 1/3 horse motor.
Take a look here for a Hitachi drive.
http://www.wolfautomation.com/Produc...roductID=17539
When you look for a motor, make sure to specify that it will be running on a VFD. Not all motors do well on VFD's
Steve
Old 02-21-2008, 10:43 AM
Steve,
Thanks for the reply. I was planning on getting a larger inverter duty motor (1HP) to maintain enough torque at slower speeds. Trying to figure out if a larger motor will fit on the machine properly. Maybe this is not necessary with a sensorless vector drive.
Greg M.
Old 03-28-2008, 04:36 AM
Legion99999 is on a distinguished road
Wow i am glad i looked at this post...i had no idea i could get a vfd with a 120v input that produces 3 phase at three hoursepower!
I don't give a damn if you don't like me, cause i don't like you cause you are not like me.
So.. Who's CNC lathe conversion kit to purchase and why? turbostang Vertical Mill, Lathe Project Log 0 01-02-2008 11:24 PM
Bench lathe Conversion Kit tootalew Mini Lathe 6 03-08-2007 12:11 PM
Manual lathe conversion to CNC - jdmech General Metal Working Machines 2 10-02-2006 04:32 PM
Mini lathe conversion kdoney General Metal Working Machines 1 08-26-2004 10:21 PM
CNC lathe conversion (again, sorry!) kong General Metal Working Machines 8 03-27-2004 01:06 PM
