Old 02-18-2008, 12:11 PM
cueshark is on a distinguished road
Question relay
i am womdering if someone can help me? i have several opto zz relays. model # 240d25. i can find data sheets on them but no wiring info. they have
1 2
4 3+
can anyone tell me the signal wire[s] also 110 in &110 out. i will appreciate any help i can get. greg
Old 02-18-2008, 12:20 PM
Al_The_Man's Avatar
1-2 is the 'switched contacts' 3-4 are the DC in.
They are usually marked plainly with a N.O. contact depicted on 1-2.
3 & 4 should be also marked with polarity and min-max voltage. 3 - 32 vdc input.
Old 02-18-2008, 12:33 PM
Smile relay info
thanks a lot AL! i srarted to put your name in the topic as you seem to have most of the answers. i wish i knew more about electrionics, but we can not all be very good at every thing. THANKS AGAIN GREG
keep relay guhl Fanuc 2 08-17-2007 07:22 AM
Where to buy VMC15 relay melzer Fadal 1 02-10-2007 09:36 PM
IR Relay Switch automizer General Electronics Discussion 7 12-12-2006 07:41 AM
Another relay ? Bear General Electronics Discussion 4 11-23-2005 05:31 PM
Need Relay help... CarveJunky General Electronics Discussion 5 07-20-2005 08:52 AM
