Old 02-18-2008, 08:33 AM
krymis is on a distinguished road
Estop and limits
Is it advisable to run the e-stop in series with the limit switches? My e-stop has 2 sets of NC 240v/10A contacts. Is this an acceptable e-stop for a
110V setup? My on/off switch is also a 240V switch. Is that acceptable for an on/off switch for 110V? Also I have a 125V/15A circuit breaker. Is that acceptable for replacing the fastblow fuse for the main power protection?
Old 02-18-2008, 05:39 PM
philserveng is on a distinguished road
yes you can do all you have stated, but only wire up the e-stops to the end limits if they are the emergency end limits, the e-stop circuit is normally a daisy chain of all e-stops. Fast blow fuses are only necessary on spindle and axis drive supply phases, so you should be ok to replace with a correctly rated overload.
EMC - Estop & Active high and low ADucci LinuxCNC (formerly EMC2) 7 10-03-2007 02:06 PM
random estop erase42 DeskCNC Controller Board 21 02-02-2007 05:28 PM
ESTOP keeps happening klick0 LinuxCNC (formerly EMC2) 2 12-17-2005 11:06 AM
Mach 2 Estop problem dentman Mach Software (ArtSoft software) 9 06-07-2005 07:32 PM
Estop HuFlungDung CamSoft Products 5 03-06-2004 01:24 PM
