If I was using 3 servo motors that at stall draw 44 amps each with Gecko 320's which allow a maximum current of 20 amps with fuses to prevent to much power to the motors, would I need a power supply capable of providing 60 amps? Where can I get transformers that could provide 60 amps? Also, how is that VA rating for transformers calculated? |
| What is the continuous running rating of your servos? Amps? VA means Volts X Amps. So if a tranny has 10 Volts and can deliver a constant 10 amps, it means it has a 100VA rating. If you are looking for a transformer with high amps, you are probably better off getting one made up for you. Just shop around with the quotes before hand though. |
| Then I guess you will need a transformer that has about 42 Volts AC output and 30 Amps rating. Once you rectify the 42Volts AC it will become 60 volts DC. The transformer will be 42V x 30A=1260 VA This will be suitable for you setup I think. If you are in any doubt you can always beef up the amperage just to make sure. Dont however beef up the voltage because this will damage your servos. |
| A 42 VAC, 30 A transformer would give you about 58 VDC, 21 A continous output. If you want 30 A out, you need to use a transformer rated for 42 A. UDC = UAC * sqrt(2) IDC = IAC / sqrt(2) You cannot get 58 VDC * 30 A = 1740 W DC out with only 42 VAC * 30 A = 1260 VA input. Arvid |
| Power Supply Question | BobLWeiss | Stepper Motors and Drives | 13 | 04-17-2005 02:27 PM |
| Power Supply ground question | chas | Gecko Drives | 5 | 04-16-2005 06:48 AM |
| FNG Power Supply Question | SteinAir | DIY-CNC Router Table Machines | 0 | 12-31-2004 09:31 PM |
| Yet another power supply question!! | chas | General Electronics Discussion | 3 | 09-16-2004 11:49 PM |
| i got a power supply question | ljoe1969 | General Electronics Discussion | 21 | 01-11-2004 11:19 PM |
