Old 02-08-2008, 08:23 AM
koslaz is on a distinguished road
Cold circular saw VFD Conversion problem.
Hi guys!
This is my Cold circular saw with a Variable Frequency Driver i just attached.
The motor is a 3 phase 1 1/2 hp induction motor 1400 U/s and before the conversion I had only two speeds to choose from, 34 and 68 U/s at the blade.
The 68 U/s was a bit slow to my taste and with the addition of the Inverter I am able to chose between 68 to 136 U/s by increasing the main frequency.
So far so good.
I was making some happy test cuts when suddenly I was hit by the current!
Luckily not with the 380 volts (EU), just 20 volt as I measure it with the multimeter.
The leak is coming from the RFI filter the inverter has (foto).
Is this normal?
I don't know how the RFI filter works. I don't know what to assume.
Do I have a ground problem?
Any help would be really appreciated!
ID:	52760   Click image for larger version
ID:	52761   Click image for larger version
Old 02-08-2008, 09:37 AM
mactec54 is on a distinguished road
Hi Koslaz
No this is not normal take the RF filter out of your system & just use shielded
cable & GROUND the INPUT end of the SHEILD ONLY, GROUND one end of the SHIELD!!
The shieled cable will take care of your RF You want to have this on the input
to the drive & the output to the motor & good GROUND'S are Needed
Mactec54
Old 02-08-2008, 01:26 PM
Hi Mactec54,
thanks for replying!
By saying its not normal,
you mean the filter is defected?
Old 02-08-2008, 03:17 PM
Al_The_Man's Avatar
That looks like a standard RC filter, prevents Inverter noise getting back into the line.
This type is usually used on the input side rather than the motor side.
But I suspect you have not got the ground wire on the unit connected to a good system ground, if you do not, there is conduction via the capacitors to ground wire, and if this is not grounded, then you will feel the effect of the leakage.
Old 02-08-2008, 05:20 PM
Hi Al,
thanks for taking the time, I was hoping for your attention!
You mean that is it normal for some leakage from the filter?
I did some Google search and I found this http://www.epanorama.net/documents/p...ounded_pc.html
If I understand correct it seams normal for the filters to have
some leakage current, I just have to make sure for grounding it.
Am I right?
P.S. Excuse my ignorance, I'm just hobbyist in electronics.
Old 02-08-2008, 06:40 PM
Al_The_Man's Avatar
Whenever capacitors are connected from the incoming supply to ground, some small current will flow, as your quoted article points out, so it is important to ensure the ground wire is connected to a suitable valid system ground.
Then you should not feel any effect, if you do, then you do not have the filter suitably grounded.
Circular interpolation problem L. Sakthivel Fanuc 3 10-17-2007 02:26 AM
X3 conversion kit problem cjd7734 Syil Products 4 03-19-2007 12:28 AM
Mazak Mill Circular Interpolation problem DublJ Mazak, Mitsubishi, Mazatrol 2 02-13-2007 11:13 AM
How cold is to cold for BP Series I CNC jho5820705 Bridgeport and Hardinge Mills 15 12-20-2006 07:13 PM
Problem machining accurate size part on my Bridgeport CNC conversion fastturbovet General Metal Working Machines 5 05-24-2005 12:01 AM
