Old 07-12-2004, 10:37 PM
owhite is on a distinguished road
Hazard due to power supply capacitor
Hey people,
if you consider a circuit diagram like the full wave bridge power supply shown on this page:
http://www.plitron.com/pages/technote.htm
when I built this circuit I used a 30,000uF capacitor at 80V.
Okay, so suppose the power supply is turned on, and then switched off. The capacitor gets charged at some lethal amount, and gets connected to a gecko drive. I've been debugging the gecko which has a plug connector. I've been carefully slipping off the connector and discharging across the caps with a pair of plyers.
Well, I dunno, I guess once the whole system is debugged then maybe it wont really matter if the caps are charged up. But there will always be a gazillion joules waiting across the terminals of my power supply. What I'd like to avoid is leaving a lethal dose in those capacitors. Think of it as protection for my cats.
Owen
Old 07-12-2004, 11:20 PM
sendkeys is on a distinguished road
Old 07-12-2004, 11:44 PM
Gold Member
Mariss Freimanis is on a distinguished road
1) The drives discharge the capacitor within a second of you turning off the AC power.
2) There are 96 Joules stored at 80VDC (J = C * V^2 / 2) but the voltage is too low to do more than tickle a little bit.
Mariss
How does a power supply work. ynneb DIY-CNC Router Table Machines 1 07-27-2011 09:40 AM
Diy Power Supply Choices berin DIY-CNC Router Table Machines 11 07-13-2005 03:47 PM
5 Volt Power Supply Tripping murphy625 General Electronics Discussion 13 02-27-2005 09:05 PM
Is this power supply rating adequate? jerryrigge General Electronics Discussion 3 11-25-2004 10:06 AM
Choosing a Power Supply for Retrofit? pfeist General Metal Working Machines 4 05-23-2004 10:36 PM
