Old 01-24-2008, 12:22 PM
xitian is on a distinguished road
Control Cable for robotic machine
I'm working on building a robotic machine and have a question regarding cabling. Will I have problems if I combine cabling for 2 steppers (8 conductors) limit switches ( 4 conductors) and misc wiring into a single shielded cable with around 20 conductors total? I want to have a single cable running from the controller to the machine with Amphenol connectors.
Old 01-27-2008, 06:45 PM
Someone has to have some ideas....
Old 01-28-2008, 08:35 AM
vger's Avatar
vger is on a distinguished road
Trouble?
The stepper and limit switches might not be a problem. It's the "misc wiring" that is in question. Is it feedback to the controler? or ? analog ? digital ?
A bit more information will help.
Steve
Old 01-28-2008, 09:19 AM
No feedback to the controller. It will be open loop. The other misc wiring is just 24 volts to power brakes and solenoids.
So does anyone know a good company to make such a cable?
Thanks for the help.
Old 01-28-2008, 10:13 AM
vger's Avatar
How about just using DB25 connectors and cable. Unless the current requirements are more than a couple of amps.
Steve
Old 01-28-2008, 05:36 PM
martinw is on a distinguished road
Dear xitian,
My humble take...
It is not a good idea to have high current conductors (eg motor current ones) running close to low level ones , eg limit switches and logic signals. The simple reason being that the stepper conductors' current, at a frequency of say 20k Hz, could possibly induce a whole load of noise on the low level signals. Screening (shielding) individual circuit paths within a single cable is entirely possible, and cable to attain this is available. It is however , hard to find, and a bit "aerospace" as regards cost, and may well not be available to you in short lengths.
Actually, there has been quite a lot of stuff posted about cable choice and electrical noise, so have a search. My guess is that putting all functions into a single cable, although elegant, might be a bit pricey...
Best wishes, and good luck,
Martin
Old 01-29-2008, 11:52 AM
keebler303 is on a distinguished road
you could try igus chainflex cables. They make several types with power and shielded logic level conductors in the same jacket. As martin said, to do it properly will not be cheap, but solutions do exist.
www.igus.com
Matt
Porter cable 7519 speed control? GalaticDan Phase Converters and VFD 4 07-11-2008 08:51 PM
Use a robotic arm instead of building cnc mill? SCCoupe DIY-CNC Router Table Machines 10 06-20-2007 03:23 PM
Robotic Mig Available RGeo Welding, Brazing, Soldering, Sealing 3 06-10-2007 12:06 AM
Porter Cable Router Closed Loop RPM Control?? vacpress General Electronics Discussion 0 03-17-2006 12:00 AM
Take a Ride on a Robotic Arm... JavaDog CNCzone Club House 6 10-14-2005 03:27 PM
