Old 01-22-2008, 08:12 AM
mzungu is on a distinguished road
Wiring a dual-coil toroidal transformer...
I need schooling on toroidal transformer wiring, specifically the dual coil versions. I've recently purchased a dual coil toroidal transformer from AnTek Inc (eBay store) that has the following specs.
700VA
Primary 1: 115VAC
Primary 2: 115VAC
Secondary 1: 39VAC
Secondary 2: 39VAC
My question is how do I determine which secondary goes with which primary, or does it matter? My plan, for now, is to energize only one of the primary coils, but I'm not sure if I need to, or even how to, identify and use the proper secondary coil. If anyone could offer some assistance with this, it would be much appreciated.
Jonathan
Old 01-22-2008, 03:57 PM
Al_The_Man's Avatar
If you do a search of the forums here there is quite a few posts on how to phase windings.
But I have used AnTek toroids and he gives the colour code normally?
What you do is take the pair you want to phase, for example the primaries, connect ONE end of each together and apply 120v power to one pri winding, you should have close to zero voltage between the open end and the other end of the primary you are using to power with.
The secondaries are the same way, if you get double the voltage then swap one end of one winding with the other.
After you have achieved zero volts, you can connect in parallel. If you connect in series and they are out of phase, no damage will result but you will get no output.
Old 01-24-2008, 07:23 AM
vger's Avatar
vger is on a distinguished road
Good post Al,
I might add that the usual reason for dual primary windings is so one can connect them in parallel for 115 V input, or in series for 230 v input. The secondaries can be connected in parallel for greater current capacity or in series for greater voltage output, or used individually if isolation is required.
Steve
toroidal transformer cueshark General Electronics Discussion 1 05-04-2007 09:31 PM
Transformer Coil Winder cjenrick General CNC (Mill and Lathe) Control Software (NC) 9 09-17-2006 09:43 AM
Question on lowering output voltage from a toroidal coil southernexplore General Electronics Discussion 1 07-26-2006 03:18 PM
Help with toroidal transformer CAM_MAN General Electronics Discussion 7 11-15-2005 07:35 PM
Help with Toroidal Transformer bill south General Electronics Discussion 6 08-02-2005 02:40 PM
