| here's the info site.....I figured mine from this... http://www.renco.com/106001.htm red and black are correct I believe white is A and green is B yellow is A not and blue is B not ( you won't connect these if you are using step/dir drivers) Last edited by Bloy2004; 07-07-2004 at 01:19 AM. |
| I have already gone through this, and posted it in this thread. http://www.cnczone.com/forums/showth...&threadid=3920 |
| sendkeys: I got some motors(cheapos) that had the 1024 ppr rencos but couldn't remove them as they sealed the hub to the motor shaft with something like locktight. since I wasn't going to use the motor with that high ppr, I busted, sawed, punched untill I had a zillion pieces of what once was an encoder. Now I can install the US digital 250's that I got a while back. Note: After destroying the renco, I noticed at that renco site the instructions for removal......which gave sources for the necessary solvent to apply to the hub/shaft to "loosen" or disolve the thin sealant between...... |
#10
| Step multiplier means that the control goes more encoder counts per step. I woulda thought that 1024 is plenty low resolution, it's a very common resolution for servomotors. But then again, I haven't really looked that hard at step and direction controllers. |
#12
Now, my number of steps per second from the computer is a bit low, so you'd have to find out what your computer is capable of and decide how much you wanted to move per step before you set the multiplier. Again, using my machine as an example, the resolution would be 1/5 inch per rev * 1/2 (rev per rev gear ratio)/(4000 counts per rev) or 0.000025 inch per step with 1x multiplier, which is a little small, so you would probably be happy with the 10x multiplier. |
| CNC conv. info help needed | Texasj10 | Shopmaster/Shoptask | 7 | 03-12-2010 04:36 PM |
| Info needed for these servos | Splint | General Electronics Discussion | 27 | 11-10-2008 03:24 AM |
| Lathe info needed | kong | General Metal Working Machines | 2 | 06-01-2007 04:45 PM |
| looking for info on HP encoder | CNC Darren | Servo Motors and Drives | 1 | 02-06-2005 12:10 PM |
