| Hi am not sure if this is the right forum to post this question appologies if not. I have a DAMICHI DX35 CNC Lathe using the FANIC 10TE-F Controler, I cant get it to talk to my pc, What I need to know is how do I configure the Fanic to correctly output the serial codes ie set to baud rate etc etc the manual talks of 5001 ~ 5003 NC codes .What is the correct RS232 Pin Configuration to achive coms. I read some posts which quote the following pin to pin config but I was not sure if these were correct for my 10TE-F fanic? >Almost all Fanucs (including the system 6) have identical >pinouts: >pin 2 = Send data (output from CNC) >pin 3 = Receive data (input to CNC) >pin 4 = Request to Send (handshake output from CNC) >pin 5 = Clear to Send (handshake input to CNC >pin 6 = Data set ready (input to CNC) >pin 8 = Carrier detect (input to CNC) >pin 20 = Data terminal ready (output from CNC) > >We always jumper pins 6, 8, and 20 together with a jumper >at the CNC side. This will avoid any "86" alarms on the CNC. >The wiring of you cable will be different depending on >whether you use a 9-pin serial port on your PC or an >(older) 25-pin serial port. Most all PCs now have 9-pin (male) >plugs, so here's the cable you need to make: >PC side CNC side >pin 2 -------- pin2 >pin 3 -------- pin3 >pin 5 -------- pin 7 >pin 7 -------- pin 5 |
| Mach2/3 and RS232 | jderou | Mach Software (ArtSoft software) | 2 | 05-28-2005 07:10 AM |
| RS232 failure to send in XON/XOFF, hangs WAITING, thermally caused. | gar | Haas Mills | 3 | 05-27-2005 07:44 AM |
