Hi all, I have a question on hall sensor connection. I have an electric actuator with the following connection ![]() The hall sensor is supposed to connect to a PLC NPN input. The RED and BLACK goes to 24VDC and 0V DC respectively, YELLOW goes to my PLC input (which the PLC input common is pull high to 24VDC). However, The PLC can't "read" the signal from YELLOW. Sadly I do not have an osciloscope. While the actuator is moving, I measured across the YELLOW and BLACK and I get voltage like 12V, 17VDC.... Did I miss out anything? Thanks all. |
| You have a source device so your PLC should be sink input. Did you tie the GND to your PLC common? with the load resistors in place, you should get a high to low reading on the sensors without any connection to the PLC. Monitor with a voltmeter between common and Yellow, by turning the motor etc as slow as possible, before connecting to PLC. If you turn slow enough you should be able to read a 24v to 0 transition, too fast and it will be anywhere in between. Al.
__________________ CNC, Mechatronics Integration and Machine Design. “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. Last edited by Al_The_Man; 01-10-2008 at 06:49 AM. |
| Hall Effect Chopper | legomanww | General Electronics Discussion | 5 | 12-20-2007 02:11 AM |
| Hall Effect Limit & Zero | Trebleplink | General Electronics Discussion | 3 | 10-19-2007 06:08 PM |
| where can I buy encoders w/Hall for brushless motors for reasonalbe? | springlakecnc | General CNC (Mill and Lathe) Control Software (NC) | 3 | 09-17-2007 04:05 PM |
| Hall encoders | danSN | Servo Motors and Drives | 2 | 11-28-2006 09:24 AM |
| C-D track to Hall conversion | interflexo | Servo Motors and Drives | 0 | 07-30-2006 07:07 AM |
