Old 07-04-2004, 12:26 AM
ty1295 is on a distinguished road
Encoder wiring hookup help
Working on wiring everything up. Came to a dilema.
My enconder on the servo has these outputs.
1- Ground
2- Ch1
3- ChA
4- Vcc
5- ChB
The rutex drive has these inputs.
1-+5V
2- A Non Inverse
3- A Inv.
4- B Non Inverse
5- B Inv.
6- Shield
9- 0V/Ground
The ground and Vcc ones are easy to match.
Not sure where CH1 from encoder needs to go into Rutex if anyplace
And do I hook up to Non Inverse (my guess) or Inverse side?
Jeff
Old 07-04-2004, 09:00 AM
arvidb is on a distinguished road
The Ch1 I guess should be ChI for Index pulse. Don't think you need to hook that one up.
From the Rutex R990H manual: "The single ended TTL encoder should be connected to one input only and a pull down resistor (470 - 1000 ohms) should be connected to other input."
So you can connect your encoder outputs to either the inverting or non inverting inputs on your Rutex card. Connect 470-1000 ohm resistors between the unused inputs and ground.
Arvid
encoder issues rutexus Servo Drives 13 05-21-2006 06:49 PM
Encoder output into 2 different inputs? murphy625 Servo Motors and Drives 2 03-23-2005 09:36 AM
Encoder Hookup murphy625 CamSoft Products 8 03-01-2005 03:46 PM
Need encoder recommendation Swede General Metal Working Machines 9 10-05-2004 08:01 PM
Encoder wiring balsaman Gecko Drives 15 12-30-2003 11:01 AM
