Old 01-05-2008, 10:03 PM
mjs79 is on a distinguished road
power supply help please
hello cnczone
im working on a cnc mill and now ready to pick up a power supply for my servos/drive boards (granite drives) . i need 170vdc and 3 amp output for my power supply with a 120Vac input . where would i find one , or diy plans .
any info would be VERY helpful
please keep in mind im a cnc newbie
thanks alot
mike
Old 01-05-2008, 11:35 PM
Al_The_Man's Avatar
There is many previous posts here on building power supplies. A source of Toroidal transformers is ebay, there is a seller that make them in various voltages.
3 amps does not seem much for servo PS?
Old 01-06-2008, 03:14 PM
hello
ill be using 2 200v, 300w ac servos , 1 200vdc max , 450w max for the z axis .
ill be using VSD-A granite drives x 3 /. what amp range should i be looking for .
thanks for any info !
mike
Old 01-06-2008, 03:36 PM
Al_The_Man's Avatar
Ok, with those motors you may be OK, if you are looking for 170vdc as in your first post, then conveniently that would be ~120v AC, so you could get away with a 750va 120/120 isolation transformer, these are quite readily available in the cheaper square lamination type.
Old 01-06-2008, 04:26 PM
thanks alot Al for your time , helps me out ALOT .
cheers
Mike
Old 01-06-2008, 08:49 PM
ViperTX is on a distinguished road
Al....I haven't worked with AC servos......but, are they DC compatible?
Thanks,
Paul
Old 01-06-2008, 08:55 PM
yes they are im sure someone can explan the details , but im not the one .
Old 01-06-2008, 08:59 PM
Al_The_Man's Avatar
Thanks,
Paul
DC, DCBL, AC servo's all need a DC power supply.
They all produce their means of control electronically.
Old 01-07-2008, 02:32 PM
hello
one last question . i called around looking for the 750va 120/120 isolation transformer .
i way its was explained to me was it would output 120Vac . dont i need the output to be in Vdc ? im sorry im confused .i found the above listed tranformer for good price , just need to be sure i understand this correct before i spend the cash .or do i need other parts to complete the supply , i have been trying to find the answers but im lost .
thanks for any info to help this newb out
mike
Old 01-07-2008, 02:54 PM
Al_The_Man's Avatar
You need to search here and elswhere for PS building,
You will need to add at minimum, a bridge rectifier and a suitable Electrolytic capacitor.
The bridge does not cost that much, you need a 10amp 250v rating minimum.
And a 250v 2000ufd Capacitor.
  #11   Ban this user!
Old 01-07-2008, 05:40 PM
thanks al i will keep searching and reading , if anyone has any links to help me out that would be great .
thanks
mike
Old 01-07-2008, 05:59 PM
ger21's Avatar
http://campbelldesigns.net/how-to-bu...wer-supply.php
How'd you supply your power supply? cnczane DIY-CNC Router Table Machines 12 08-28-2011 05:13 AM
diy power supply eloid General Electronics Discussion 9 04-21-2007 01:05 PM
More power from switching power supply R.thayer General Electronics Discussion 4 03-10-2007 07:03 PM
power supply help Gads General Electronics Discussion 1 02-20-2006 07:01 PM
Power Supply from a computer power supply jmytyk General Electronics Discussion 21 01-11-2006 02:56 PM
