Old 01-03-2008, 07:30 PM
GEORGETOUBALIS is on a distinguished road
Unhappy My servos overheating
Hi.!
I need your opinion about a problem.
My motors are
http://www.motioncontrolgroup.com/pr...formance-specs
Voltage rating up to 90 Vdc
Rated Speed: 4000 RPM
Rated Power: 245 watts (0.33 HP)
Current at Cont. Stall Torque, o-peak A dc 5.56 Amp
Current at Peak Torque, o-peak A dc 38.93 Amp
Resistance, L-L R 1.33 ohms
I finish the power supply
http://www.cnczone.com/forums/showthread.php?t=47073
I was told to engineer to make it 75 V DC 30A
the p/s by a mistake I think is 92-93 V DC 30A.
I take the risk and I power up my servo controller which has a label that says "Max Input voltage 80V DC"
Nothing wrong happened..(Like smoke) The number of Errors were reduced but not eliminated.
It is strange but I got an error when the system stays with out motion for 10-15 min.
when I reset it and start the mach 3 immediately works fine for 15-30 or 45 minutes without problem.
After a few tests I realize that the Z axis motor is overheating
All motors has a temperature about 100F. The Z Axis motor has more than 180F (I can' t left my hand on it more than 2-3 sec)
do you have an idea why all these happened to me (the errors and the overheating servo motor)
thanks
George Toubalis
Old 01-03-2008, 11:33 PM
unterhaus is on a distinguished road
the voltage being too high is probably not a good thing. You may have your gain set too high and it is overheating due to the high voltage at zero velocity. For whatever reason, your link didn't' work
Old 01-05-2008, 12:03 AM
SpeedsCustom's Avatar
SpeedsCustom is on a distinguished road
Check that your resistors are letting the right amount through, if you have resistors.
-Speed
Controller Overheating?? Tazzer AjaxCNC Control Products 1 02-20-2007 02:40 PM
Need DC servos... WilliamD Servo Motors and Drives 4 03-06-2006 03:57 PM
Y Servo Overheating screensnot Fadal 19 02-09-2006 07:40 PM
Router overheating alarants DIY-CNC Router Table Machines 11 10-21-2005 10:39 PM
Rough drive == overheating 10bulls PicStep Controllers 5 07-12-2005 10:35 AM
