Old 12-31-2007, 10:27 AM
eagle550 is on a distinguished road
Problems with steppermotor, controller and driver
I have some problems with my steppermotor. I have the IBC-400A controller and a BSD-01v2 15-75mA driver. The problem I have is that when I connect everything the way I think it should it is not working. I'm using the anloge joystick function. The thing is that the motor is making noise and virbrations. When I change load the noise and vibrations also change but the shaft of the motor doesn't move any. The input of the driver is 23V but when I measure the voltage between 2 leads on the motor I only measure 0.5 volts. I also can rotate the shaft free when the power on. I hope some one can help me with this problem. Below here you can find the links.
Hardware manual controller IBC-400A
Software manual controller IBC-400A
Driver manual BSD-01v2
I tryed it with 2 different motors. But with they had the same problem. I have now connected this motor Lin engineering 208-17-01. Is it possible that the motor needs more current the rotate the shaft then the 75mA he will get from the driver (on the motor it say's he need 0.8A). I ordered this motor ADM 1220-V12-09 but I don't have it yet so I tryed it with an other motor until I recieve my order.
Greets,
Arthur
What is max current for my steppermotor? sierra General Electronics Discussion 5 08-26-2007 01:59 PM
what controller with this Driver cozymkiv General CNC (Mill and Lathe) Control Software (NC) 0 08-06-2006 09:46 AM
15XT Spindle Driver Problems integral Fadal 4 08-22-2005 02:25 PM
Building encoder with a steppermotor per.e General Electronics Discussion 10 05-13-2005 10:47 PM
Steppermotor plays a whistle? Hioxz Stepper Motors and Drives 4 03-12-2005 05:02 PM
