Old 06-29-2004, 07:16 PM
yorttroy is on a distinguished road
Wire Gauge
I am running 3 power max 2 (116oz, 65v, 1.16v) to a Xylotex controller with a 28v 15a power supply. What gauge of wire should I run from my steppers to the controller? My furthest connection is less then 6 feet.
Old 06-29-2004, 07:47 PM
sendkeys is on a distinguished road
Old 06-29-2004, 08:02 PM
sol sol is offline
Gold Member
sol is on a distinguished road
Yup, it does not require much...but were it my nickel I'd buy a 25 ft. 16 ga. extension cord and cut it to length... protective jacket, flexible, cheap, available, and comes with a ground wire if you want it.
Old 06-29-2004, 10:11 PM
ger21's Avatar
You probably have to use 22ga to hook up to the motor, but run that to a nearby terminal strip and then use a larger gauge.
Old 06-30-2004, 08:29 PM
Thank you for the information, I will run 16 gauge all the way.
4 Axis Wire EDM Application squarewave CamSoft Products 4 09-30-2008 10:18 AM
Motor controller development for laser owhite Laser Engraving & Cutting Machines 21 06-25-2008 06:10 AM
Wire EDM show and tell Graham S CNC Plasma and Waterjet Machines 5 01-21-2005 03:17 AM
Wire Gauge CapnC General Electronics Discussion 1 01-06-2005 05:45 AM
Wiring - What gauge for PS vs Limits vs Other AJ_Mac2001 General Electronics Discussion 10 01-31-2004 11:13 AM
