Old 12-13-2007, 02:00 PM
choelzen is on a distinguished road
Spindel speed PWM controller
I looked and haven't found a spindle speed controller for Mach3 for a generic router. What is needed is a feedback to the computer that tells Mach3 the RPM and a circuit that powers the router from the PWM pulses generated by Mach3.
The index sensor can be a Hall sensor mounted to detect the rotation.. An optical system may be a problem with dust. For high speed routers a divider/counter to lower the pulse count to Mach3 will be needed.
I designed a PC board to drive the 120V universal wound motor in most routers. It can be populated to run 5, 10, 15 or 25 amp motors.
Comments please.
Chuck
Old 12-13-2007, 03:28 PM
Al_The_Man's Avatar
Most ordinary routers are Universal motors and can reach high rpm, you need a prox that has a high freq characteristic, I have used the Honeywell Automotive gear tooth sensor GT1 series, they can also be obtained at auto scrap yards, they are used for Ignition timing on an engine.
Also you could supply the digital tach feedback to the spindle controller, for a while there were surplus Treadmill motor controllers that were intended for Universal motor control, They were based around the motorola TDA1085 IC and had digital tach feedback input and Triac control.
The IC was designed by Motorola for Washing machine Universal motor control and worked quite well, I still have one on my band saw I converted.
Old 09-09-2008, 10:45 AM
gfc62's Avatar
Platinum Member
gfc62 is on a distinguished road
Can you give more information on the speed ocntrol board you designed?
Old 07-26-2010, 08:12 PM
Zero Cool is on a distinguished road
Yes Please more info on your motor controller!
Old 07-28-2010, 12:07 PM
Drools's Avatar
Drools is on a distinguished road
There is a unit available from CNC4PC that will do what you are doing however it is not a closed loop system. It just takes the output from Mach3 and sets the speed accordingly. It works fine for the people that do not need an exact rpm control. I have yet to try it at low speed as that will be the kicker, low speed usually means less torque on universal motors, correct?
This Motors + This Speed controller? JMcDonald Benchtop Machines 12 09-30-2007 10:46 PM
Quicker 2 spindel satneo Mazak, Mitsubishi, Mazatrol 2 08-17-2007 07:05 PM
New Speed Controller for Routers arturod Product Announcements & Manufacturer News 1 08-14-2007 01:01 AM
speed controller? slp_prlzys General Electronics Discussion 10 09-04-2004 03:40 PM
Speed Controller recommendations? paulried DIY-CNC Router Table Machines 2 05-13-2003 05:39 AM
