Old 12-06-2007, 07:21 PM
kboudy is on a distinguished road
voltage LMD18245
Hey all-
I reckon this is a bit of a newbie question: I'm constructing an LMD18245-based circuit (the "Typical Application" circuit in the LMD18245 datasheet) & wanted to confirm something. I'll be using it with a SM2006B
motor rated at 3.6V & 2.0A/Phase. I'm under the impression that I can essentially ignore the voltage rating, since I the LMD18245 will supply a steady 2A current (using a 10K resistor for current limiting).
So, it's okay that my supply will be 12V even though the motor is rated at 3.6V right?
Thanks!
Keith
Old 12-06-2007, 10:24 PM
pminmo's Avatar
pminmo is on a distinguished road
Yes you are correct, as long as you select the appropriate resistors to set your current limit. You will get better performance though if you increase your supply voltage.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 12-10-2007, 10:05 AM
Thanks Pminmo
The motors & components should be here any day now. Got the circuit etched & can't wait to put it together. Thanks to your reply I have the confidence to forge ahead
LMD18245 picstep need help zoltan General Electronics Discussion 29 02-09-2010 07:12 PM
Help..Stuck at relay ext dc voltage missing but dc voltage OK ? Dirky Bridgeport and Hardinge Mills 24 11-27-2007 07:33 AM
LED Voltage Mr.Chips General Electronics Discussion 3 02-03-2007 01:10 PM
lmd18245 or sla7051m TinkerDJ Open Source Controller Boards 32 10-29-2006 05:40 AM
Max voltage tekno PicStep Controllers 3 04-02-2006 05:49 PM
