Old 12-04-2007, 08:33 AM
CASTLEVILLE is on a distinguished road
high house voltage
My problem I am having is the voltage coming out of the wall is 120vac, should be 110vac I would think. The controller I am retro-fitting(ajax) says to start with 110vac. What can I do to get the incoming volts under control? This is also my first retro-fit so I am trying to get everything right before I smoke anything.
Eric
Old 12-04-2007, 08:55 AM
jpgdesigns is on a distinguished road
110vac is nominal number... your 120vac will be fine.
Old 12-04-2007, 09:03 AM
Al_The_Man's Avatar
I think you will find the current service now in N.America, at least it is in Canada is 240 and 120.
You still see appliances marked 110v.
Old 12-04-2007, 10:30 AM
cool thanks for the quick reply. now that is cleared up for me it is full steam ahead.
High Voltage wire CNCadmin Laser Engraving & Cutting Machines 9 02-27-2012 08:19 AM
High Voltage Drives Enteralterego Fanuc 4 08-15-2006 08:08 AM
Power supply voltage too high spoiledbrat General Electronics Discussion 8 06-13-2005 09:39 PM
PSU Voltage seems high. mnewsholme Hobbycnc (Products) 10 04-26-2005 03:26 AM
Transformer voltage seems too high for Gecko bgolash General Electronics Discussion 14 12-25-2004 10:35 AM
