Old 11-22-2007, 04:44 AM
derkiow is on a distinguished road
dc motor controller diy diagram
hello forum ...
has any one got any idea where i could get hold of a diy circuit drawing for a controller that wil be used on an electric car handling 100 plus volts and any where up to 400 amps...... all the best...... derkiow
Old 11-22-2007, 08:52 AM
NC Cams is on a distinguished road
Sure: Get A LOT of money and a LOT of MOSFETS and build your own. Simply "scale up" some model train/car speed controls.
in all seriousness, the R/C car boys were EASILY pulling 80 to 100 amps out of nicads in the early/mid 90's - sometimes by design, sometimes by accident. In doing so, they learned how to switch lots of current relatively easily and inexpensively. Car starters readily pull 80 -200 amps as well. There is higher voltage switching going on in the new hybrids but the $'sss are probably NOT DIY affordable.
Swithching THAt much power is not easy nor will it be cheap to do - I'd be disinclined to find that many DIY'ers who'd have balls enough to do it let alone the budget to buy the parts.
If the circuit/switch has to "live", that is one thing, if you only have to throw the switch a couple of times (IE: race car or display concept), a simple "throw away" switch or ganged switches such as an automotive starter solenoid(s) might work as a remote triggerable off/on switch.
IT will be interesting to see the direction this thread morphs into.....
Old 11-22-2007, 09:51 AM
Karl_T's Avatar
Karl_T is on a distinguished road
Standard stuff for an electric fork lift. Find a bone yard and take the whole unit.
Karl
Old 11-24-2007, 03:15 AM
I have found mosfets that that can handle 84amps each and 500v for 30$ each, so the price is not too ba, just need a circuit diagram now can anyone help...........derkiow
Old 11-24-2007, 03:29 AM
thanks for the replies....not any fork lift in the scrap yards where i live in the uk and ones i have found, parts are going for silly money. This project has to be cost effective , i want to save money on my travel cost and be green as well, in that order...derkiow
Old 11-24-2007, 03:30 AM
Khalid's Avatar
Khalid is on a distinguished road
Its difficult to understand...
Old 11-24-2007, 03:45 AM
WayneHill's Avatar
WayneHill is on a distinguished road
Khalid:
Testicular fortitude
Old 11-24-2007, 04:14 AM
Khalid's Avatar
hahahahahhaa:-)
Old 11-24-2007, 05:57 AM
balls apart, seriously is anyone out there who can help , can tackle most things but modern electronics are way over my capabilities , just been looking at radio spares site and they do some 200amp/100v mosfet and i been told that i need a pwm device to switch the mosfet i take that would be some kind microchip .........derkiow
Old 11-24-2007, 09:43 AM
Al_The_Man's Avatar
For many years there have been articles,books,groups all engaged in Electric Car development, I would have though that there would be a whole source of information out there for DIY.
Also I remember seeing Application notes from semi manuf like motorola (now Freescale) and others like IR in their HexFet Designers Manual, see if you can get a copy, they have a design for 48v 400a DC motor drive. I got my copy in '93, but it may be available in PDF now, the App note is AN-941b, includes regen as well.
  #11   Ban this user!
Old 11-24-2007, 07:21 PM
It is one thing to switch on fets to run a DC motor, it is another to switch a potential of nearly 40,000 watts frr an electric car.
We learned some VALUABLE lessons about inductive and resistive switching issues while switching 50-70 amps at 4-6 volts with the R/C stuff and mosfets - switching that much power for an electric vehicle would be something to be done with a lot of care,
Electrons do funny things under those situations and you don't want to be between the path to ground that they may be seeking - especially thru a poorly designed "switching circuit"..
Especially for/by someone who admits that "modern electronics are way over my capabilities", It is hardly a place to learn how to do DIY, OJT switching of a potential of 40,000 watts. If you're not careful, you could get killed or kill somebody.
Did the lights just flicker or was I imagining something???
  #12   Ban this user!
Old 11-25-2007, 05:47 AM
thank you for the your replies, i have been doing some looking into dc motors controllers and i have found that mosfets are available right up to 200amps (very expensive) but smaller sizes are cheaper if you by them in quantities of 50 say. Whilst i admit to having only a basic knowledge in electronics i have been connected with high voltage, high current situations all my working life and i treat safety as paramount ... from my investigations so far the electronics are readily available, not expensive when compared to buying a manufactured controller such as curtis etc etc.I have built many projects over the years and you always learn something new and challenging and you overcome a lack of knowledge of something by asking questions, is'nt that what forums are for? .....all the best derk
D.C motor controller swarfmacdaddy General Electronics Discussion 9 08-02-2007 12:28 PM
Stepper motor controller heepofajeep Stepper Motors and Drives 1 11-27-2006 09:27 PM
DC motor 21 amp controller? DennisCNC General Electronics Discussion 0 10-02-2005 09:58 PM
How about this motor/controller set-up? Nonoriginal DIY-CNC Router Table Machines 6 03-01-2005 09:49 AM
help with a DC motor controller.... mike3 General Electronics Discussion 24 08-06-2004 08:19 AM
