Old 11-19-2007, 04:25 PM
mtompson is on a distinguished road
Question Fuses & drivers
if fuses are used between the power supply and each driver, would their rating simply be equal to the power supply peak output?
many thanks for any help...
Old 11-20-2007, 02:08 AM
I have been advised to use fuses 50% higher than the peak ( once I've worked out which peak! ) the power supply I'm using is a PS407 - 40V DC at 0A and 38V DC at 7A but in mentions a 9A peak in it's pdf doc. And the drivers are MSD542 both from motion control products Ltd.
The output from the power supply is being divided into 3 so I assume I can divide the 9A peak as well? ( and then maybe 50% on top? ) I simply want to protect the drivers from any nasty surges.
thanks for any ideas..
MT
Blowing 4amp Fuses tajord Hobbycnc (Products) 16 02-27-2007 07:03 AM
Blowing fuses kaderick General Electronics Discussion 2 12-05-2006 11:34 AM
Blown Fuses sommerjd General Electronics Discussion 6 10-01-2006 04:02 AM
Blowing the fuses rocks101 Hobbycnc (Products) 2 02-26-2005 03:00 AM
Confused about fuses. FLUTE HEAD General Electronics Discussion 9 09-24-2004 11:54 PM
