Old 11-18-2007, 11:19 AM
kiltjim is on a distinguished road
pminmo BOB and NC E-Stop switch
I have a BOB built and everything is running great. Except that I do not have an E-stop switch hooked up yet. I have some excellent take-out components from some equipment and would love to use what I have. Unfortunately, the E-stop switch is a NC switch, and the circuit calls for a NO switch. Is there a way that I can change the circuit to use it?
I was also thinking that having the circuit take NC switches would be a safer method. This way I could hook up several switches in series, and then any single switch would cause the circuit to stop.
Any suggestions?
Old 11-18-2007, 02:23 PM
Al_The_Man's Avatar
E-stop circuits are generally wired with NC devices as a safety precaution. Also it conforms to the code recommendations.
You can change the logic by using all the NC safety devices in series and they would pick up a relay with a NC contact, this contact would be open in normal operation, closed on e-stop.
Old 11-19-2007, 11:58 AM
Here I was trying to figure out a complex circuit to use the thing, and never thought of a relay. Leave it to someone else to point out the obvious.
Thanks Al!
Old 11-19-2007, 01:20 PM
pminmo's Avatar
pminmo is on a distinguished road
You can use a normally closed switch, in fact it is preferred. Not sure where I might have communicated that you can only use normally open?
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 11-20-2007, 06:15 PM
Maybe I am misinterpreting.
If the switch is closed, the circuit latches (all the time, unless the switch is pressed). If I press the reset switch, it momentarily un-latches (machine could run), but then latches again. I tried simply changing the way that Mach3 sees the signal, but no good.
Am I doing something wrong?
Old 11-20-2007, 07:57 PM
pminmo's Avatar
Oh, your referring to the website version, I didn't think about that one. Too many days have passed..... Skip the circuit, just use Pad 15 as the input, the other side to a gnd pad.
Webhost problems PMinMO.com pminmo CNCzone Club House 1 10-17-2007 01:45 AM
Pminmo electronics SCHootie Open Source CNC Machine Designs 13 02-23-2007 10:40 AM
Questions for pminmo dfro PicStep Controllers 0 07-01-2006 11:14 PM
