#14
| The design of my table is someyhing like this. working area 1000mm X 700mm Then I deside not to give about 30.000$ for this table (everything is Bocsh rexroth). ![]() The basic design stay the same but with linear tables from Parker. I allready have the X and Z X: parker XR406 800mm Z: parker XR404 200mm ![]() In 2 day I will have the other 2 Y Axis XR406 800mm. Everything from Ebay... (about 2000$) For the Calculations Now.! The encoder is 250 CPR The Two Y Axis Has 10mm lead With the Mach3 give about 45000 pulses per sec I have 2700 screw RPM 45cm per Sec and 0.010mm per step the motor has max speed 4000 at 90V dc then with 2700 need only 60.75 Vdc The X Axis has 25mm lead With a Reduction 2.5/1 The motor needs the same Voltage (60.75 Vdc) I thing that with mach3 pulse limitation my p/s (75V dc 30A) is OK.. as the motor need only 60V DC. I am graphic designer not an engineer. Engineering is my hobby so is possible that my opinion is tottaly wrong. |
#15
| I dont see anything wrong in your calcs for achieving speed so if your drives are continuously faulting then the only other 2 things it could be is tuning of the motors/drives or increase the gearing ratio to the ballscrews. I've never built that type of system but 45cm per sec seems way to fast to me. I'd suggest going 4:1 gearing that will reduce the strain on the motors and increase resolution and you'll still get a respectable speed. I hope this helps. |
#16
My CNC machine is for this application. http://www.ijfisnar.net/movies.htm Thats why I need Speed. |
#18
| The X Axis is 25kg (with motor) The Z Axis is 9kg (with motor) I have 2 Y Axis With 2 motors to move the Y Axis. The minimum speed I want to reach production rate requirements is about 20cm/sec. |
| Small servo systems and power supply | imserv | Product Announcements & Manufacturer News | 4 | 04-03-2008 11:11 AM |
| Servo power supply help --Please | turbotoys | General Electronics Discussion | 6 | 09-13-2007 03:17 PM |
| Servo Power supply | elogicca | General Electronics Discussion | 17 | 11-21-2006 09:52 PM |
| power supply sizing vs. servo rating | Erick Davidson | General Electronics Discussion | 1 | 06-06-2006 03:08 PM |
| Sizing servo power supply? | bsc52001 | DIY-CNC Router Table Machines | 2 | 01-30-2004 11:20 PM |
