Old 11-08-2007, 09:15 PM
alfredr1 is on a distinguished road
PWM 49hz
Whats the best way to generate a 49 Hz PWM with the ability to change the duty cycle. Is there a chip that can do that? Im currently using the Axiom 8Mhz Hc12 microprocessor. The smallest pulse i was able to generate was 120hz.
Old 11-09-2007, 12:47 AM
epineh is on a distinguished road
Have a look here :
Simple PWM Generator
I ended up going for the 8038CCPD - Precision Waveform Generator which gives me a range of between 0.01 to 300KHz, but there are some great suggestions in the thread above.
Good luck.
Russell.
