| Hi every one! I'm Mark and I'm new here. I need to do a control circuit for a stepping motor, reverse & forward in order to pass the semester... but I'm stuck with the motor, a Mitsumi M49SP-1. The teacher gave it to me so I’m not allowed to use other motor. Sincerely I can't figure out if it’s a unipolar or bipolar motor, the thing it's that has 4 wires - black brown orange and red,. Reading around in some pages appear that 4 wires mean bipolar and other says that it’s unipolar so really I'm getting confuse . In addition to that, in the data sheet of the motor says that it’s a 4 phase motor, but in the excitation method says that it’s a 2-2 Phase excitation and next to that says unipolar driving. … WTF?So it’s a bipolar motor using unipolar circuit to be controlled? Here’s other data of the motor: • 4 ohms • 7.5 step degree • Rated current/ phase - 431mA/216mA • Rated voltage – DC 12V -24V • Working voltage - DC 10.8 -13.2V and DC 21.6 -26.4V Now… the thing is that I need to design the control circuit for it, but it's not allowed using PIC’s or PC interfaces (the thing its turning a little bit difficult). If you want to take a look at the bottom of this page (its in Spanish but the diagrams can be read in any language) x-robotics.com/motorizacion.htm It’s written that I can use a L293b (integrated H bridge) for bipolar or a ULN2003 (darlington config) for unipolar but as I said earlier I don’t know what kind of motor is this and also I don’t know how to do it. The only thing that I know it’s that the final circuit should look like this robotstorehk.com/motordrivers/images/motor-controller-1.jpg THE FINAL DAY TO SHOW THE CIRCUIT IT’S NOVEMBER - 23th So I’ll really really appreciate any help you could provide me. Thanks to everyone! Last edited by The_JediKnight; 11-08-2007 at 12:06 AM. |
| Yes u can contact www.pminmo.com . probably he will help u in this regard. |
| Unterhaus thanks for clearing that issue .. but now that i know that its a bipolar stepper.. can i use the last circuit of this page?http://x-robotics.com/motorizacion.htm If so what should I do in order to put a Variable Resistor and control the stepping forward and reverse move? |
| JediKnight, Dude, you are making it all sound like it's a burden and imposition on you. You are taking a technical course and from that I surmise you have picked a technical major in school. If so, you should love what you have chosen and you should see your assignment as a happy and worthy challenge. The salvation to your assignment is only 2 D-flops and a pair of XOR gates away. It is a throw-away easy solution. To get it though you must show me a willing eagerness to learn instead of seeing the assignment as a burden. Are you willing to have that attitude? If yes, contact me off-list. I design motor drives as my profession. Mariss |
| sorry about sound like you said Mariss. it's not an excuse but the thing is that i need to desing 4 more diferent projects for other teachers: A) for one of those i'm allowed to use a PIC to control what ever I want B) other it's control a speed, reverse and forward of DC motor wich use betwen 2 -6 A C) using PIC's, CMOS, TTL or any thing ...i need to control an hydraulic circuit. D) the 3rd is design a control mode using a Siemens PLC and this one the stepper motor (forward and reverse) so i'm getting a little bit crazy with all that stuff so I need to do it all at the same time at the easiest and cheapest way possible. |
#10
| If the device is to be battery powered and the stepper on the same power buss as the power supply, use a LM2940 regulator IC instead of the 7805 - MUCH better performance with servo voltage induced spikes with the 2940 than 7805. Also "free" over voltage and reverse polarity protection. |
#11
so at the end should look like this Last edited by The_JediKnight; 11-08-2007 at 09:36 AM. |
#12
If I understood you correctly, you said you have a 4-wire stepper motor. A six-wire (or an 8-wire) can be wired for use either unipolar or bipolar, however, (as Unterhaus said) a 4-wire motor can only be used bipolar. Therefore, you must use the LB293b to drive this motor. Alan
__________________ http://www.alansmachineworks.com |
| Strange circle behavior, 151B control | swarf_rat | Bridgeport and Hardinge Mills | 11 | 07-15-2007 10:08 PM |
| Spindle Control Circuit? | boguski.1 | DIY-CNC Router Table Machines | 10 | 03-17-2007 11:24 PM |
| Stepping motor control | Zeekh | General Electronics Discussion | 0 | 12-10-2006 01:21 PM |
| Stepping motor control... | Zeekh | Stepper Motors and Drives | 0 | 12-10-2006 08:55 AM |
| URGENT: 2J Quill return sping replacement -URGENT | NC Cams | Bridgeport and Hardinge Mills | 8 | 02-13-2006 11:48 PM |
