Old 11-01-2007, 04:04 PM
audioandy1762's Avatar
audioandy1762 is on a distinguished road
Help Please:- Stepper Not Changing Direction
Hi
I have nearly finished the control side of my router build, I have had my stepper motors running ( not connected to anything mechanical just running on my bench) everything seemed ok so started to concentrate on the mechanical design/build. I have not had my steppers running for a while so tonight I thought I would give them a run, I am using Mach 3, Gecko 210's,
CNC4PC breakout board, all the settings in MACH 3 for all three drives are exactly the same. I started to jog the axis one at time +/- direction when I noticed that my X axis was not changing direction from + to - I held down the - direction key the DRO in MACH was saying it was going in a - direction then the motor locked up, I released the key and pressed the - key again this time it went in the - direction. I then pressed the + key the motor changed direction no problem, pressed the - key again the motor continued to go in the + direction then locked again.
The above problem only seems to be when changing from the + direction to the - direction and only on my x axis.
The first thing I tried was changing the motor, problem still persisted. I then changed the Step/Direction pins in MACH 3 from my X axis to my Y axis (thinking behind this was to eliminate my PC and breakout board) the problem still persisted but now obviously when I press the Y axis button.
The only common thing that I can think of at the moment, is the Geko drive unless someone out there has had a similar problem and can point me in a different direction and hopefully help me rectify the problem.
Thanks in advance
Andy
Old 11-07-2007, 05:15 PM
Sorted
Thanks to Jerry (CJL5585) the above problem now seems to be sorted.
THANKS JERRY
Stepper turns only one direction jhowelb Stepper Motors and Drives 0 10-03-2007 08:52 PM
motor changing direction by iteself using picstep oliverthepig PicStep Controllers 1 04-30-2007 05:11 AM
stepper motors turn only one direction Mike Boarman General Electronics Discussion 7 11-24-2006 05:43 PM
Stepper only going in one direction? ScuD Stepper Motors and Drives 7 12-09-2005 06:28 AM
Stepper rough 1 direction randyf1965 PicStep Controllers 6 05-25-2005 03:17 PM
