| Hello, I'm new to CNC and I'm trying to convert old Crusader M to mach3. I have purchased C11 breakout board and (3) Skyko Pixie boards. I believe that I wired it correctly. However when I hook up anilam glass scales to Pixie board axes start to drift untill they trip overtravel switches. Any idea why? Can I use glass scales from anilam with Pixie? Any input would be a great help.... Thank you. |
| If your glass scale linear encoders output ttl level (0v low and 5v high) quadrature signals then the Pixie would not know the difference between a regular rotary encoder and the glass scale linear encoder. They would both look and work the same. If your axis is drifting, then the problem is most likely noise in your parallel port cable, breakout board, or in the cable from the glass scale linear encoders. All of your cables NEED to be shielded, and you must ground the shield. |
| czech, I assume you are using the scales for feedback to the drives. To make life easier for your self get rotary encoders and put them on the motors and start making parts instead of trying to hunt down every glitch and bum.
__________________ Dennis |
| exactly.. If there is any sort of backlash in the system - it will be almost imposible to tune. The only way around this is only using the scales for postion feedback and having separate encoders/tach on the motors to do velocity feedback. (but mach isn't going to do this) http://jmkasunich.dyndns.org/cgi-bin...-02-20-08.html (or just put some encoders on the servos as dennis said) ![]() But - your drifting problem is unrelated to the backlash.. Could it be you have the encoder wires reversed? (this will make the servo run away) |
| Converting From Mach2 To Mach3 | duraflap | Mach Mill | 1 | 10-20-2007 12:00 AM |
| Converting from anilam to pc controller | aerofab | General CNC (Mill and Lathe) Control Software (NC) | 3 | 04-03-2007 12:38 PM |
| Mach3 converting dxf files problem | randyf1965 | DIY-CNC Router Table Machines | 7 | 04-19-2006 12:28 AM |
| Converting your (Rutex) R990mb setup to Mach3 | ynneb | Servo Drives | 0 | 08-25-2005 10:37 PM |
| converting to dfx | qsacracer | G-Code Programing | 31 | 04-26-2005 04:43 PM |
