Results 1 to 7 of 7
Thread: PC Based Hardware Controller Kit Needed
    May 2004
    I am new to this hobby and would like to build a simple cnc machine. I would though like to purchase the controller as a kit or completed product so I don't have to build it. Is this possible or am I out in left fielf here.
    Jan 2004
    South Africa
    I don't know why the address did not post but check out the 'links' you will find the info there . There are
    numerous suppliers of the types of kits you need.
    hope this helps
    Mar 2003
    Shelby Twp, MI....USA
    A lot of people use the Xylotex stepper drivers on small machines, http://www.xylotex.com .Some also use Geckos, http://www.geckodrive.com . The machine is actually controlled by software, such as TurboCNC, http://www.dakeng.com , or Mach2, http://www.artofcnc.ca
    Apr 2004
    http://www.embeddedtronics.com/microstep.html looks like a nice setup ifyour good with electronics
    May 2004
    I found an outfit that had 3 steppers and a control card fo $160.00. I'll be danged if I can find it again. Does anyone know the web site?
    Just John
    Apr 2004
    Eureka, CA
    Could it have been www.stepperworld.com?
    Paul F.
    May 2004
    Thanks, I appreciate the help
    1. Open Source CNC Controller Specification
      By gregmary in forum DIY CNC Router Table Machines
      Last Post: 12-04-2005, 10:58 PM
    2. Assembling Gecko based controller
      By walter in forum Gecko Drives
      Last Post: 07-19-2005, 05:30 PM
    3. Dsp Based mini cnc controller
      By CNCadmin in forum Product and Manufacturer Announcements
      Last Post: 01-05-2005, 07:59 AM
    4. Speed/Torque Boost on Allegro 5804 Based Controller (???)
      By FrankG in forum Stepper Motors and Drives
      Last Post: 11-28-2004, 09:03 AM
    5. CNC Retrofit - Kit verses turn on and go
      By MetDetect in forum General Metal Working Machines
      Last Post: 07-12-2004, 11:06 PM
