Page 1 of 2 12 LastLast
Results 1 to 12 of 14
Thread: Schematics/Circuit Diagram for 3 Axis Driver with Parallel Port Interphase
    Oct 2007
    India
    Hi... I am new to this Board...but I have to say this is a wonderful place to find ANYTHING related to CNC...
    I am from India and most of the off-the-shelf drives as well as Drive Kits mentioned in most of the posts are from the US...but for a Hobby CNC Enthusiast like me it becomes hard to get them imported and go through customs procedures due to them being classified as an Electronic Equipment and the conversion rates along with the duties make it many times costlier than how much it would cost if it was to be made on your own. Can you guys help me out with complete circuit diagram and component list for a 3 Axis chopper drive for Nema 23 steppers ( 1.5- 2 Amp would be sufficient). I would like to interphase it to the computer using the Parallel Port. So it would be great if you could provide me the interphase circuit diagram too.
    Hope you guys can help me out.
    Thank You
    Mar 2003
    Shelby Twp, MI....USA
    Dec 2005
    Take a look at/through the TI/Unitrode web site.
    They have a lot of stepper and servo drive IC's. They also have some circuit diagrams for the high current amplifiers needed to interface the servo/stepper encoder/driver IC's to the motors (servo) and/or the motor phase coils (stepper).
    I don't know of any full blown "kit" plans to go from the bare parallel port to the motor - this does require some full blown integration of the soft and hardware.
    A good place to shop/check would be the Mach users group. Surely, some of the users have crafted up exactly what you're trying to do - join, post an inquiry and wait for a reply. You'll either get a kit or link to someone/someplace who's done what you're trying to do.
    Mar 2007
    Portugal
    if look for a3977 ic you will find lots of info at this web site and also at pminmo.com
    look for open source projects.
    if you look for something easy to solder, TA8435 from Toshiba it's an alternative.
    can find a small board design at http://www.ottop.republika.pl/sterownik8435.shtml
    it's the same ic used by Nanotec-(IMT901)
    all drives need power supply, and mainly STEP and DIR info.
    it all depends on how easy to find components at your place.
    Attached Thumbnails Attached Thumbnails Schematics/Circuit Diagram for 3 Axis Driver with Parallel Port Interphase-dscn1186.jpg
    Oct 2007
    India
    Thanks guys. Those websites were really useful... I was wondering what kind of stepper motor is best for CNC Engraver. Unipolar or Bipolar?
    Mar 2007
    Portugal
    if your stepper has 4 wires it is for bipolar. if has 8 wires you can use it both ways. it is described pros and cons at one of those links.
    I prefer bipolar only because it's easier to choose cables and connectors. even if buying xlr connectors and shielded cable with 4 wires from Igus the diameter is not big.
    you will find there are other things to consider like torque an so on.
    Registered workfine's Avatar
    Oct 2007
    algeria
    TA8435 document pdf
    some help about TA8435 driver ,you translat it italian document
    http://www.sigala.it/sergio/robotica...-24jul2001.pdf
    Mar 2007
    Portugal
    if you want to use ta8435, you will find schematic and pcb drawing at
    you only have to download it at
    http://www.ottop.republika.pl/download/imt901.zip
    need to install Eagle to use it. it's free.
    to make it work connect your stepper then apply at least 24V. and logic 5V. next connect ENABLE to ground to turn on the drive, and see your stepper spinning.
    and don't forget to use a good heatsink.
    I have found another link with board design where you can put a 7805 ic, and you only need acrobat reader.
    http://www.piter.mily.pl/index.php?i=1
    http://www.piter.mily.pl/index.php?i=2
    but didn't test it.
    it seems easy to build and is an ic used by Nanotec.
    Jun 2008
    Sri Lanka
    Your site is great
    Jun 2008
    Italy
    Quote Originally Posted by rmsimoes View Post
    but didn't test it.
    Piter link doesn't work.
    Mar 2007
    Portugal
    it is true
    I have seen already that link was removed, but I can supply schematic and pcb design if you want to test it.
    any way, I prefer that I am using at the image from http://www.ottop.republika.pl/sterownik8435.shtml:
    with 5 minutes using heat transfer method I have done a really good job.
    for the price it seems to me a nice solution. the last one I have done was with small fan attached to heat-sink to cool it down.
    Attached Thumbnails Attached Thumbnails Schematics/Circuit Diagram for 3 Axis Driver with Parallel Port Interphase-imt901.gif   Schematics/Circuit Diagram for 3 Axis Driver with Parallel Port Interphase-imt901_pcb.pdf   Schematics/Circuit Diagram for 3 Axis Driver with Parallel Port Interphase-imt901pcb.gif
    Jun 2008
    Italy
    Hi, this pcb looks a new version, doesn't it?
    Have you included the 5V voltage regulator (7805?)? Nice!
    I found a very similar circuit (here).
    Pls, 1 question about C1. The 2 circuits differ mailnly for C1 value. 1000mF instead of 2200-4700mF. What is better? TY
  • Page 1 of 2 12 LastLast
    1. Plz help me interface IM483 driver to parallel port
      By dondeaida in forum General Electronics Discussion
      Last Post: 08-10-2012, 06:10 AM
    2. Parallel L298N driver circuit help
      By Sidco7 in forum Stepper Motors and Drives
      Last Post: 02-28-2011, 10:56 PM
    3. Any plans for optocoupler circuit for parallel port?
      By mbwittig in forum CNC Wood Router Project Log
      Last Post: 01-31-2007, 07:09 AM
    4. Servo driver system for parallel port indexers
      By imserv in forum Product and Manufacturer Announcements
      Last Post: 07-22-2005, 01:26 PM
    5. Parallel port circuit
      By Kerri Ann in forum General Electronics Discussion
      Last Post: 03-19-2005, 01:23 AM
