Old 10-10-2007, 08:52 AM
krz2_2000 is on a distinguished road
Bridgeport Series 1 R2E3 Encoder Count
I'm in the preocess of tuning this mill with a dynomotion controller and wanted to know if anyone knows the encoder counts per inch? I can't find any literature about this. Any help would be greatly appreciated.
Old 12-29-2007, 12:26 AM
DennisCNC's Avatar
DennisCNC is on a distinguished road
The most for sure way is to take the cap on the end of the motor off to see the encoder and read the model number and usually they have the count # listed.
Did you install the dynomotion controller your self?
Dennis
Old 12-29-2007, 06:39 AM
Gold Member
HillBilly is on a distinguished road
It has to be at least 10,000 ( 1 / 10,000 = .0001 inch original step resolution )
If I am remembering correctly it is exactly 10,000 counts per inch.
Darek
Old 03-25-2009, 12:23 AM
moghul is on a distinguished road
bridgeport heidinehen encoder
hi all its 125 lines encoder that gives in full round 500 steps.
and motor and screw is 1 and 2 ratio. it gives 200 step in one mm.
shabbir
Old 03-25-2009, 12:35 AM
Gold Member
The Heidinehen encoders were used on machines with the Heidinehen control. The R2E3 was a Bridgeport control ( BOSS 8 ). They used SEM motors and BEI encoders.
Darek
Old 05-20-2009, 06:34 AM
greeder88 is on a distinguished road
If anyone is still interested the Bridgeport Boss 8 & 9 (R2E3, R2E4) use 250 ppr encoders which gives you position accuracy of .0005 per step. Taken from the manual.
Old 05-20-2009, 09:24 AM
cut more is on a distinguished road
Hilbilly,
I have a series 2 Boss8, It has the heidenhain encoders on it. I am pretty sure they are 500 count encoders but I will look tonight. I am pretty sure the screws on mine are .1" lead as well.
regards,
Cutmore
Bridgeport R2E3 Boss 8 Encoder problems leftyrowe Bridgeport and Hardinge Mills 8 11-23-2009 09:03 AM
R2E3 Series II - How to communicate with it? bellamyj Bridgeport and Hardinge Mills 9 09-29-2008 10:24 AM
R2E3 Series I CNC krz2_2000 Bridgeport and Hardinge Mills 4 08-03-2007 02:30 PM
Retrofits - Bridgeport Series 1 R2E3 Ray Casler Bridgeport and Hardinge Mills 0 03-29-2006 10:26 PM
Bridgeport Series II R2E3 Mill Questions rkdygert Bridgeport and Hardinge Mills 12 03-05-2006 10:46 PM
