Old 10-05-2007, 03:26 PM
Big John T is on a distinguished road
How to calculate the voltage for a stepper
I'm using a Gecko 203v drive on a Nema 23 stepper with the following specifications:
Rated Current 2.8A/phase
Resistance 1.1 ohm
Inductance 3.82mH
http://web2.automationdirect.com/sta...stepmotors.pdf
The Gecko drive is rated for up to 80vdc
How do I figure the best voltage to run?
John
Old 10-05-2007, 06:49 PM
GaryCorlew's Avatar
GaryCorlew is on a distinguished road
Amps times phase resistance, So 2.8 x 1.1 = 3.08 volts
Old 10-05-2007, 08:30 PM
pminmo's Avatar
pminmo is on a distinguished road
As you go up in the supply ratio to coil voltage you get better high speed performance. I believe gecko recommends three to twenty-five X. So that would put you around 75V max.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 10-05-2007, 08:51 PM
Eurisko is on a distinguished road
The 3.08 volts is the rated voltage of the motor.
Gecko recommends running the motor from 4 times (minimum) to 25 times (maximum) the rated voltage.
My G201 also specifies a minimum power supply of 24 volts.
In your case, 24 to 75 volts should suffice. The more voltage you use, the more power you'll get. Too much voltage may cause the motor to overheat.
Don't exceed this motor's rated current of 2.8 amps when configuring the Gecko.
Although heatsinking for the Gecko is not required under 3 amps, I'd take the safe route and put one on.
Old 10-06-2007, 12:13 PM
Thanks for all the help. BTW, the G203V instructions recommend 4 to 20 times for the power supply voltage. So it looks like a 60 volt power supply is for me.
John
Old 10-29-2007, 02:57 PM
rgammage is on a distinguished road
Hello Big John T
Remember that most drivers use some form of current limit and so 60V is only fed to the motor for a fraction of a second and then turned on and off repeatedly so the average of ( 60 * Time on/Time off ) will be close to 3V.
Richard
What voltage for bipolar stepper 2 A, 1 Ohm ? vroemm Stepper Motors and Drives 24 09-09-2010 02:03 PM
Stepper voltage jdholbrook Stepper Motors and Drives 1 02-23-2006 11:06 PM
Stepper / Voltage ckrantz Stepper Motors and Drives 10 10-03-2005 08:02 AM
Stepper motor Voltage metron9 Stepper Motors and Drives 3 11-15-2004 08:10 PM
Stepper voltage glentner General Electronics Discussion 7 03-30-2004 12:02 AM
