Old 05-25-2004, 02:30 AM
gv71 is on a distinguished road
want to add 4th axis to stepperworld fet3 board
I bought a FET3/cruiser about a year ago (the fet4
wasn't available yet) and I want to add a rotary table
to my mill. I am running cncpro. How do I drive this
extra axis do I have to add another paralell port? Thanks.
Greg
Old 05-25-2004, 08:42 PM
balsaman's Avatar
balsaman is on a distinguished road
You don't Have to run another parallel port, but you would need to run jumpers or something from the unused Fet 3 pins to the new single axis board for step, dir, enable etc.
Eric
I wish it wouldn't crash.
Old 05-26-2004, 03:59 PM
Thanks Eric for the info. Now how do I do that as I am not an electronics wiz. Is there some info on the web somewhere? Thanks again!
Greg
Old 05-27-2004, 07:55 PM
balsaman's Avatar
I would ask Russ at stepperworld which pins are available and where they are located on the board. I don't have the board in front of me (I sold mine). I think russ has single axis boards as well.
Eric
Old 05-29-2004, 11:07 AM
Eric,
Russ said there was only 2 pins available for the extra drive and he said he doesn't have any 2 pin(step and direction) drives. I thought I could just wire them into the remaining pins in the parallel port as only 14 of the 25 pins are being used, am I missing something here. I'm sorry to keep bothering you and thanks for helping me.
Greg
Old 05-29-2004, 11:10 AM
Here is what Russ wrote back to me: "It is possible that you could drive a forth motor by using the 2 aux output pins to interface with another driver. However, I don't have any single
axis drives that use just step/direction interface (2-wire interface)"
4020 4th axis problems little bubba Fadal 3 06-13-2005 09:08 PM
fet 3 15 amp 3 axis driver board (stepperworld) mike10 Stepper Motors and Drives 17 04-29-2005 10:30 PM
4th Axis UKRobotics General Metal Working Machines 7 03-19-2005 09:25 AM
4th axis controller board? CNCadmin DeskCNC Controller Board 1 08-30-2004 03:38 PM
4th axis add on to a shop saber dac DIY-CNC Router Table Machines 0 08-22-2004 09:58 PM
