Old 10-01-2007, 12:33 PM
chostelet is on a distinguished road
HIP4082 - Continuous High Side with Charge Pump
Hello,
I'm new to CNCZone but I found this site being populated with expert people !
I'm interested in designing a DC/DCC Booster for my railroad model. This booster is essentially a H-Bridge being used in anti-phase mode. I want this booster to support DCC mode (roughly a 20kHz signal) as well as DC (continuous) signal. Voltage will be less than 20 volts and current intensity would be less than 5 amps. And last, it must support polarity auto-reverse for an adjustable trip current.
I've looked at the LMD18200 (from NS) which almost all what I needed but this chip is too clever as it doesn't permit to detect short-circuit (while it protects itself against this condition).
Now I'm considering the HIP4082 (for which I got already some samples) but I'm wondering how this device will behave in continuous mode. I'm thinking of using two charge pump circuits (one for each H-side MOSFET) to provide the HIP4082 with two floating supplies between AHB and AHS pins (same for B side). Has anyone already experienced that?
An other option could be HIP4080/81 but at this time I have not been able to get samples for a prototype.
Regards
Old 10-02-2007, 02:58 AM
AbSat is on a distinguished road
I tryed to build a 3 phase stepper driver with the HIP4082 but stopped trying because too many ic's got defective during test. I used isolated floating supplies for the highside driver. Under low load conditions it worked ok but with steppers connected and normal load of 3A I did not got it working properly. I tryed all the protection methods I found but still not a stable driver so I switched back too Nmos / Pmos fets and transitor driverstages.
I did not have the proper measuring equipment to find out the real reason why the chips broke. But searching the net I found a lot off problems with this driver chip.
AbSat
Old 10-02-2007, 05:46 AM
Hello,
I'm now considering the HIP4081 which provided the necessary charge pump. I've asked Intersil for samples but may not receive them (hobbyist).
Any good/bad experience with this chip? (I see not so good feedback for HIP4082)
My Charge-Pump circuit Guillote Gecko Drives 1 07-23-2007 10:58 AM
Charge Pump ??? jack55 General Electronics Discussion 6 04-21-2007 02:59 PM
Diy Charge Pump Circuit? zigmart General Electronics Discussion 6 03-18-2007 07:28 PM
Charge Pump circuit raytor Machines running Mach Software 1 10-16-2006 04:23 PM
Charge pump mlaws1172 Screen Layouts, Post Processors & Misc 0 01-03-2006 10:46 PM
