Old 09-28-2007, 04:52 PM
Mr.Chips's Avatar
Gold Member
Mr.Chips is on a distinguished road
Question Have my Steepers Assumed Room Tempeture Too? (DIED)
Because of my miswiring between the Xylotex stepper controllers and the steppers, my stepper controllers have died.
I have stripped everything out and am starting over. I think my steppers are OK but I need someone to give me a professional opinion.
If I measure across both coils on each stepper I get aproximately the same reading on all steppers, for each coil.
I didn't find any shorts between coils, nor between any coil and the case.
Is there any further test I could perform before I call them good and connect them to the new stepper drivers?
Old 09-28-2007, 05:15 PM
pminmo's Avatar
pminmo is on a distinguished road
I doubt you damaged your motors. But, how did you miswire that damaged your controller board?
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 09-28-2007, 05:22 PM
Mr.Chips's Avatar
Gold Member
Controller - Stepper connections
Here are the motor connections that I used:
A# on Board is connected to Red 1-2 on Stepper
A on Board is connected to Black 3.4 on Stepper
B on Board is connected to White 5-6 on Stepper
B# on Board is connected to Green 7-8 on Stepper
This is the link from Scorcheror, telling me the correct connections:
SORCHEROR
ok mr chips,i got it your hooked up wrong at the board,here how it should be
A on the board=1+2
A# on the board=5+6
B on the board=3+4
B# on the board=7+8
im not sure what colors you used but stick with the numbers,i got them from powermax
Building CNC Plasma table - Machinist Died!! Crayola CNC Plasma and Waterjet Machines 2 02-05-2007 10:38 PM
Help! Building CNC Plasma table and Machinist died! Crayola General Metalwork Discussion 0 02-05-2007 02:06 PM
Help, my Geckos may have died! bkkpool Gecko Drives 2 10-30-2006 01:30 PM
Mill drive motor died. devinchi Shopmaster/Shoptask 12 05-14-2006 12:47 AM
Slow Steepers - newbie jdemille Mach Software (ArtSoft software) 7 01-02-2006 06:04 PM
