Old 05-14-2004, 12:41 PM
tpworks's Avatar
tpworks is on a distinguished road
Creating a chopper drive with discrete components using the L297
Originally posted by Ferenczyg
The chopper control 'only' provides the frequency of control signals for the power stage. You can use phase chopping for discrete semiconductors, or inhibit chopping signals for the non discrete IC's like l298 or l6203.
If you use discrete bridge, try to use a rsense value to create about 1V of Vsense, that is about 0.125 ohm for 8A. Reccomended chopping freq is about 20Khz. Because chopping is created comparing vsense to vref, you want to put vref about 1v, typically with a 1 to 5 voltage divider from the logic voltage.
More details, images and accuracy @ http://www.st.com/stonline/books/pdf/docs/1734.pdf
hope it helps
Fer
What chip do you recommend I use for an AND gate?
will the 74LS09 work, a Quad 2-input AND gate with open collector?
Old 05-14-2004, 09:01 PM
Ferenczyg is on a distinguished road
Why open collector? You will need pullups then..
BTW, I beware you about myself not having build a discrete Hbridge controlled by a L297, I'm struggling with a one side pcb L297+L298 design for the OpenSource CNC and a L297+L6203 design for my own pleasure by now. So plz do not trust blindly in me, if any release of magic smoke to the atmosphere occurs and is not from my own semiconductors I will feel very guilty
The main info I handle about using discretes is from the ST datasheets. In the datasheet of the quote (fig 17 by example) you need a negate signal for every phase, so I think you will need a 74LS04 too..
Fer
Old 05-14-2004, 09:43 PM
tpworks's Avatar
Fer,
same here , I have built several unipolar motor controllers starting with (Luberth's design) my first about 3 years ago for my first pcb mill. Then I came across the 5804 . But you know how it goes, I got the fever and have to go bigger stronger faster, sure don't plan on putting no 6 mill into it though.
I have these huge bipolar motors I am determined to make a driver for. There is nothing more gratifying than to be able to say " I made that with my own two hands". so everything I learn is from reading looking and listening, and a little common sense thrown in . So any info is always appreciated no matter what your credentials, I think we are all here to help one another and share our knowledge and expierences even if they do produce a little smoke now and then.
Tom
...He who makes no mistakes makes nothing! ...
Tom
Old 05-18-2004, 12:04 PM
tpworks's Avatar
Any input here will be greatly appreciated and when I finish the artwork I will post a link to it here.
so far I gather I need a 7408 Quad two input AND gate,
7404 Hex inverter(although I don't see where this fits in the block diagram of the L298)
L297 step/dir chopper driver
I am going to use IRF540 and IRF9540 because I already have a quantity of these. On the block diagram for the L298 it shows a little circle on the input of two of the and gates anyone know what this is?
Tom
Tom
Old 05-18-2004, 03:32 PM
lt paul's Avatar
lt paul is on a distinguished road
the circle indicates an inverter
Old 05-18-2004, 03:40 PM
pminmo's Avatar
pminmo is on a distinguished road
Tom
I really wouldn't use old ttl, if you want use the 74HC series, but in reality I would use the 4000 series cmos because of noise immunity. Have you looked at the open source driver thread?
http://www.cnczone.com/forums/showth...&threadid=4079
specifically this one of mine:
http://www.cnczone.com/forums/showth...2870#post32870
It has a link to Eagle files that could be the start of your design.
Why do you want to use discrete components, higher voltage, current, how much? Have you considered two 298's as they can be paralled for higher current drive.
The other point I would make is making a discrete chopper will be much more of a challenge than the unipolar drivers you mentioned.
Phil
Old 05-18-2004, 08:45 PM
tpworks's Avatar
Phil,
I need 8 amps and as cheap as possible
Tom
Tom
Old 05-18-2004, 10:08 PM
pminmo's Avatar
That would take 3 298's in parallel. Your probably headed down the right path with discretes. Make sure your PC layout is appropriate. Plenty of copper in the high current paths, plenty of copper for the current sense resistors.
Phil
Old 05-19-2004, 12:37 PM
tpworks's Avatar
Is the 4081 (buffered AND GATE) a replacement for the 7408 acceptable
and the 4069 (Hex Inverter) for the 7404?
Tom
Tom
Old 05-19-2004, 04:05 PM
pminmo's Avatar
Probably, my only concern is the guaranteed high level input voltage vs the L297. 99.8% sure it won't be a problem, but you might want to check out the 74HC series to see if they are pinout compatable just in case. The L297 Vout High guaranteed min is 3.9V, but that's at a much higer current load than the 40xx cmos will be. The Vin High guaranteed min is 4.0V (Assuming 5VDC power). For the inverter the 40106 I believe has a little lower input voltage spec.
Phil
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
  #11   Ban this user!
Old 05-24-2004, 12:29 PM
tpworks's Avatar
This is what I have so far (Eagle version 4.11 schematic)
just rename dropping the .txt part
I'll have to redo this and remove the file as it is corrupt I can't open it either.
  #12   Ban this user!
Old 05-24-2004, 03:52 PM
pminmo's Avatar
tpworks, I can't get it to open with 4.11. I'm doing a save target as from ie and dropping the .txt ok. But eagle says the file is corrupted. tried it twice.
Phil
Avr Unipolar Chopper Drive H500 Open Source Controller Boards 26 01-08-2009 08:42 AM
Using drive components from an impact printer playinsteel DIY-CNC Router Table Machines 0 03-01-2005 09:05 PM
