Old 09-04-2007, 07:09 AM
karl1's Avatar
karl1 is on a distinguished road
DIY 1-8 axis PC controller card
I'm kicking around the idea of putting together a DIY, open source PCI card ito be used as a 1 through 8 axis controller; can be used for stepper or servo motors on any combination of axes. PID compensation with velocity and acceleration. Modes of motion include jogging, point-to-point positioning, contouring, electronic gearing, position tracking, linear and circular interpolation. A Mach3/EMC interface/with a active "closed loop" error handling. Dual encoders for every servo/stepper axis. Optically isolated I/O.
This would very much be DIY approach to a Galil Motion Control Products. I don't plan on mass marketing or making kits, but leaving it open source on both electronic design and firmware. Any suggestions would be helpful. I guess the success of this idea would need the early input for initial design. I see it as a PCI card connecting to a breakout board of some type; this could then feed to Servo Amplifiers or Stepper Controller. Any comments would be appriciated!
Karl
Old 09-04-2007, 08:07 PM
cwiliam's Avatar
cwiliam is on a distinguished road
wish i could help
wish i could help but don't know much
The project seems very interesting
Can't wait to see it
Old 09-04-2007, 10:39 PM
Al_The_Man's Avatar
What kind of LSI Processor are you thinking of using ? Something like the TI or Motorola DSP etc?
What about the HMI part of it, will this be the Mach/Galil already partly developed?
A decent on board PLC with output interface to OPTO G4 module boards would be an asset.
Old 09-05-2007, 11:39 AM
karl1's Avatar
I hope to use what I am comfortable with: Motorola, TI or Philips NDX for the controller. Either Xilynx or PLX for the PCI front end bus controller part. I know that breadboarding isn't that tough for me - I've got 25 years of design and prototyping to fall back on. The Mach/Galil portion may just be wide open - haven't thought much about that. The programming of a plugin may just be a joint group effort of anyone following the open source idea. I guess I should revisit the Mach Galil plugin to try defining a board that mimics their I/O scheme. Open sources may just bring a lot of expertise along for the ride. I am using Eagle Schematic Capture on this project since the freeware version will allow others to enjoy/critique/join in.
G4 (I am assuming your talking of OPTO22's G4 bus) is easy enough to include a 50 pin header going to a 16 module OPTO22 board. The I/O modules would have to be defined in software - and the PLC progamming could work off that! I even have a ton of Analog OPTO22 stuff in my *junk* box to push through an analog contoller portion of the board. Hmm... analog strain gauges, temp monitor, and air pressure/flow monitor; just wait till I ge my hands on a plasma cutter to mod!
Thanks!
Karl
controller card swiftden Stepper Motors and Drives 4 06-09-2007 07:48 PM
Delagrange 4XCNC15B Controller Card ronald44 Open Source Controller Boards 0 05-16-2007 01:33 PM
Which controller card? jcolley LinuxCNC (formerly EMC2) 2 09-30-2005 08:40 PM
Designing a controller card arvidb General Electronics Discussion 20 06-28-2004 10:33 AM
hobby cnc controller card sixpence DIY-CNC Router Table Machines 11 02-23-2004 02:52 PM
