Old 08-04-2007, 06:14 AM
SPEEDRE is on a distinguished road
Momentary Switch
I have some questions that have nagged me for a while now and really need to be answered. What if, I use a momentary push button switch to jog an axis ? First, how would that be wired? Where would it plug in? How many conductors wire to use? I would use keygrabber to alocate the proper keystroke variable. OK here's the deal. I want to build a simple, real simple, jogging pendant for my homebrew mill and I think I can use these switches to accomplish this. Please someone tell me if I'm right or wrong about this idea. I think three of them wired up will jog the axis they are assigned to????????? Please help me!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 08-04-2007, 06:23 AM
ger21's Avatar
I think you'd need two for each axis to jog in opposite directions. Just wire them to the parallel port or bob, one wire to an input pin, one wire to ground. Then assign the input pins to the OEM Triggers and assign the jogging keys to the triggers (all on the input pins setup page). You don't need keygrabber for this.
Old 08-06-2007, 04:45 PM
Ger21, I am severely electronically challenged, I mean brain dead to it, what would the schematic look like? That, is really what I'm looking for, the schematic. I can follow a wiring diagram , without the electronic symbols. Have any ideas that you could put to paper for something like this? I would be appreciative.
Old 08-06-2007, 06:34 PM
ger21's Avatar
The switch should have 2 wires. One wire goes to the input pin on the parallel port or bob, the other goes to a ground pin (18-25) or the ground on the bob.
Momentary Glitch or Glimpse of Great New Feature? Mike Nash Forum Questions or Problems 0 05-01-2007 08:19 PM
limit switch and home switch setup Runner4404spd General Electronics Discussion 0 12-15-2005 07:58 AM
Is it possible to use the home switch as the limit switch as well? Darc Mach Software (ArtSoft software) 2 10-23-2005 12:50 AM
Limit Switch / Home Switch in Software Sanghera General Electronics Discussion 6 11-01-2004 05:58 PM
